Results 1 to 11 of 11
    Registered Member Two Rings DavidTurbo//'s Avatar
    Apr 09 2007
    95 Mustang GT Droptop wit dubs
    Connecticut
    Ruff racing wheels 18X8.5
    Ruff racing wheels 18X8.5, Will these fit in the front of my car? 99.5 1.8tQM? Is a 225/40-18 too small for a 8.5" rim?
    99.5 1.8TQM Black on Black,
    18X8.5" RUff Racing, H&R Race springs
    A little system
    95 Mustang GT Convertible wit Dubs
    Get $20 off your first order
    http://www.audiforums.com/m_495181/mpage_1/key_/tm.h
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Ruff racing wheels 18X8.5
    I think that tire might be a bit stretched.
    I am running that size on my 8" and it is perfect.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings VOoDooGTX's Avatar
    Mar 07 2007
    1987 Porsche 944 Turbo
    New Paltz, NY
    my friend is putting 9.5s on his car.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    I run that tire size on wheels the same size as yours. It has a little stretch. I think it looks good.
    the homebrew'd s4
    Veteran Member Three Rings Euro's Avatar
    Sep 18 2006
    Bimmers
    Portland
    IIRC, 225's are supposed to fit anywhere from a 7''-8.5'' wheel. So its going to be pretty damn stretched. BUT it will fit.
    I'd run a 235 on a 8.5'' wheel, but thats just me.
    Feb 27 2005
    North Wales, PA
    Depends on the tire. Some companys tires are wider then others. Falkens run skinny while dunlop and yokohamas run wider.
    Ruff Racing 279 18X8.5 with yokohama parada spec 2's 225/40/18. I hope this answers your question. There is barely any stretch
    Feb 27 2005
    North Wales, PA
    whoops, forgot the picture
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    damn poopie, your car is gorgeous. is that an oempl front lip. i really need to get one of those.
    Feb 27 2005
    North Wales, PA
    thanks. yes that is a cupra r oem front lip
    Apr 09 2007
    Connecticut
    Quote Originally Posted by Poopie View Post
    Wow your car looks awesome man! What do you have for an offset on those? and how much is your car lowered? I have H&R race springs, do the front tires rub? I had nexen n300 on my other car and after going thru three popped tires! 7 total I switched to nankang ns2 and the nankang were definatly narrower and they were both the same size. Thanks for your help
    A little system
    Feb 27 2005
    North Wales, PA
    offset is et35. its about 24.75 fender to ground all the way around. With rolled fenders I only rub on the fender liners on very sharp downhill turns under braking. Nankangs sucked. No grip at all. basically it was hard plastic.
