Results 1 to 3 of 3
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Need some technical opinions-I have been looking into and doing a bit of searching
    in the archives and trying to compile a decent answer on most things, but want some current input. I am considering a nitrous setup for my stage 2+ S4. I want to have that extra power if I need it, as I don't plan to go stage III for a while most likely. After reading, it seems a wet kit is the only way to go for power, and most importantly, safety of the motor. I don't really want to do any more than a 75 shot, and of course, I will build up to that with logs every step of the way to make sure it is safe and functioning correctly. The kit I have narrowed it down to is a NOS Sniper wet kit. At under $400, it seems like a good price for what it comes with. I have a link to the kit at the bottom. Anyways, what do you think about this kit? Anyone have installation photos or experience with this kit or a similar setup? Thanks
    http://store.summitracing.com/partde...5&autoview=sku
    Senior Member Two Rings 01 S4's Avatar
    Jul 23 2007
    01 S4, 87 yj trail rig
    long island NY
    Re: Need some technical opinions-I have been looking into and doing a bit of searchin
    there was one guy on here that did a nos setup i think it cost $1200 with all needed parts its probably better to start saving for new turbos you will be much happier with power thats all ways there
    01 S4 -James-
    2001.5, 6 speed
    Darintake, 710N, Samco TTB
    GIAC X
    clutchmasters stage 4 and LW flywheel
    K04's ...there screaming
    piggies, ssac catback
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Id direct all your Qs to Snowtrooper/jared@stasis, i remember he had a pretty solid setup that worked well with the 2.7T.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
