Results 1 to 3 of 3
    Mar 14 2008
    PHX
    01 motor mount replace
    Does anyone know where I can find a DIY for a motor mount replace of a 2001 S4? I just did the tranny mounts and it was easy..but now I am trying to do the motor mounts and it is a pain in the butt. I took the air box out of the ride and looked for a way to get the mount out and I cant...There is no access to the bolt...I did take the sway bar off the bottom and those 3 15mm bolts out...to get the bracket out...
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 09 2007
    Re: 01 motor mount replace
    Here is a DIY article on Audiworld that is pretty in depth. Hope this helps.
    http://forums.audiworld.com/s4/msgs/1945094.phtml
    Cheers
    Mar 14 2008
    PHX
    This looks good.. Thanks
