Results 1 to 20 of 20
    Established Member Two Rings sykotoyRS4's Avatar
    May 20 2007
    Sydney Australia
    Wheel Spacers for RS4 - need help
    Ok so im told hubcentric are the way to go...? use them on the street but dont use on track as creates more stress etc , so remove for track? sound right?
    Also, while using spacers for street only i will need longer wheel bolts....?
    If this is the case where do i get the longer ones from , does one thread fit all?
    Phantom Black Euro Spec/ I Pod / Solar Roof/ Buckets / Flat Bottom Wheel
    Mods/ H+R Srings and Sways, full milltek with 100 catts non res/non valve
    Current RS4 B7 1/4 mile record holder :O) (stock) 12.883
    Feb 15 2007
    Re: Wheel Spacers for RS4 - need help
    I don't know about the track and stress situation, but you will need longer bolts with spacers 3mm and up!!
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2023 Mini Cooper SE - White Silver Metallic
    Dec 05 2006
    So. Cal.
    Your spacer will come with the bolts. Also almost all spacers are hubentric for the car that you order them for.
    Veteran Member Three Rings NewImageS4's Avatar
    Dec 07 2004
    2007 RS4
    SE PA
    Not all spacers come with longer bolts (some do, some don't) and only 20mm or bigger are hubcentric.
    Past cars:
    99.5 A4 1.8
    01.5 S4
    04 A4 1.8 Ultra Sport
    04 S4
    12 S4
    12 Golf R
    15 SQ5
    17 SQ5
    14 RS5
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by NewImageS4 View Post
    You might be right there, I got a set of 10mm spacers on my Maxima and they slide right over the hub centers. There is still enough original hub to center the wheel.
    My bad, thanks for the correction.
    Veteran Member Two Rings
    Mar 07 2005
    Oregon
    H&R's are hubcentric from 8mm up. I have H&R 10mm F&R and I'm getting some steering vibration from 60-70 mph. Had my front wheels checked for balance as well. Going back down down to 8mm spacers which my car seems to like better.
    Dec 07 2004
    2007 RS4
    SE PA
    Quote Originally Posted by Randy M View Post
    I'm sure your right, I had 5mm H&R that were not.
    BTW, I ment 10mm, H&R box reads 20mm kit.
    Past cars:
    99.5 A4 1.8
    01.5 S4
    04 S4
    12 S4
    12 Golf R
    15 SQ5
    17 SQ5
    14 RS5
    Veteran Member Three Rings jerrym's Avatar
    Nov 23 2007
    4 Door Saloon
    im running 10mm spacers on my oem wheels with longer lugs :)
    2009 Mercedes-Benz E63 AMG
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2008 Audi RS4 (gone)
    2005 BMW M3 (gone)
    2003 Mitsubishi Lancer EVO 8 (gone)
    "After a certain point, money is meaningless. It ceases to be the goal. The game is what counts" -Aristotle
    Veteran Member Four Rings 1FastS4.Com's Avatar
    Feb 19 2004
    Tesla Y Performance and Audi TTRS
    Get them from ECS Tuning with the longer wheel bolts they are hub centric. That what I have and no vibrations!
    || 2017 Audi RS3 || 2018 Tesla P3 ||
    Dec 05 2006
    So. Cal.
    isn't ecs selling H&R spacers?
    i don't want any issues, so i'm just gonna bit the bullit and get four mtm spacers.
    Apr 27 2004
    2018 GTS Cab, 2020 AMG A35, 2021 XC40 PLUS parking lift
    H&R are hubcentric from 8mm up. On my B6 A4, I had 8mm H&R spacers on my front (longer bolts were noot included) and 15mm MTM spacers that came with longer bolts. No vibration and an agressive look ...
    Need a hotel in Ottawa? Try Albert@Bay or Best Western Plus Ottawa Downtown
    PM me for AZ discounts !
    2020 XC 40
    2018 991 Cab GTS
    2020 AMG A35
    Previous rides: B5 A4, B6 A4 Avant, B7 S4 Avant, B7 RS4, TTS, B8 A4, S3, 2019 Targa
    Senior Member Three Rings Sleepy 1's Avatar
    Apr 03 2007
    B6A4, B5 Passat, my girls B7A4
    Quote Originally Posted by Stevelev View Post
    Love that avant, clean and simple.
    The black Futrell RS4 in "the official RS4 pic" thread has 10mm spacers, you could also look for the picture thread he posted and pm the owner. He owns/runs two performance tuning shops. One in Portland OR the other in Bellevue WA.
    Nov 23 2007
    4 Door Saloon
    i dont have that issue?
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2005 BMW M3 (gone)
    Veteran Member Four Rings PESAPC's Avatar
    Aug 19 2007
    B7 RS4 + B8 A4 Avant + JEEP SRT8
    Okay ... I am intrigued ... I too have 10 mm and have steering wheel vibration ... did you transition to 8's and did the situation improve?? OEM or aftermarket wheels?
    B7 RS4 - JHM R-Clutch/LWFW/CP/Short Shifter + Milltek Exhaust + JHM Piggies&Tune + F/R Brembo BBK + HRE
    B8 AVANT S-Line FMIC + F Brembo BBK + BBS + STaSIS Exhaust + GIAC Tune
    BOTH Ohlins Coilovers + Rear Sway Bars + Michelin PS2 + Tint
    Mar 07 2005
    Oregon
    Quote Originally Posted by PESAPC View Post
    Well I drove mine on the freeway last night after putting on the 8mm H&R spacers and there is the most faint of vibrations. Compared to the 10mm spacers though it's almost not there. With the 10's it was visible if you took your hands off the wheel going between 60-65 mph. My tires balance perfectly. Who knows maybe it's the rotors but I kinda doubt it at 2,500 miles.
    Having said that the H&R 8mm spacer are seated perfectly to my stock wheels. They are conical hubcentric and they also have a lip that extends from the conical seat that fits into the inside of the wheel. It's hard to explain but if you look at both the 8mm and the 10mm you'd see that the 8mm spacers are the better of the two for our stocks wheels.
    Dec 05 2006
    So. Cal.
    That's it! I've heard too many bad stories with vibration and the H&R spacer. I'm def going to go with the MTM's. Sorry that you guys have to go through this. That shouldn't be the case as H&R is supposed to be a great company with great products.
    Mar 07 2005
    Oregon
    I'd have to see them but I can't imagine that the MTM's would be any better.
    Aug 19 2007
    I asked DPE and Eric over at Supreme Power to ship me some new ones / thinner to see if that has the improving / desired affect. Thanks ... I will report back ... oh, and mine insert into the wheel hub too like you describe.
    Dec 05 2006
    So. Cal.
    There was another member here or on audiworld that had vibration issues with H&R spacers and switched them out to MTM's and it solved the problem. I forget where I read this.
    Nov 23 2007
    4 Door Saloon
    i think im going to run on 8mm .. and get rid of the 10's
    1997 Toyota Supra
    1994 Nissan R32 GTR
    2005 BMW M3 (gone)
