Results 1 to 8 of 8
    Active Member Two Rings ForthRightAfter's Avatar
    Jan 09 2008
    04' S4 Sedan
    Hempstead, NY
    Sun Shade Retrofit?
    I have a B6 S4, wondering has anyone ever installed the three sunshades for the rear passengers?
    those screens on the doors or the one in the rear?
    if so where can i buy this?
    Established Member Two Rings vovpar's Avatar
    Nov 30 2007
    04 S4
    Sacramento, CA
    Re: Sun Shade Retrofit?
    the rear door ones would be easy, the back window one would be hard cuz its electric
    04 S4 6Speed DOLPHIN GREY~iForged~APR~REMUS~Sebring~
    Established Member Two Rings Addicted2Bass's Avatar
    Mar 15 2008
    2005 Dolphin
    Quote Originally Posted by ForthRightAfter View Post
    might have to call the dealer, this isn't really a common "tuner" part, so i doubt you'll find it on the web
    Veteran Member Four Rings todd1010's Avatar
    Jun 17 2004
    Jacksonville, Florida
    I may be wrong but I believe they are part of the door panels so it would require to buy new door panels. Yes the rear would probably require some more work.
    Jacksonville's Premier Paintless Dent Removal
    Got A Ding? Give Us A Ring!
    904.705.DING (3464)
    http://www.dent-technique.net
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    I think this would be an expensive PITA.
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    i have it on the car stock. and the door panels are not the same.
    the rear deck is not the same as yours....probably not something you
    want to try to swap.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Yeah, more expensive than it is worth. Just tint the windows. I have the shades and have yet to use them. The rear door shades are part of the door panel and retract into the door panel when not in use.
    Veteran Member Three Rings derleicaman's Avatar
    Aug 11 2005
    NW Suburban Chicago
    You can retrofit the rear sun shade. You need the sunshade, which comes with a new rear deck trim. You need the dash switch to activate it. You also need to run the wires to the shade from the switch, and run power to the switch. It is a minor PITA to do this, but black on black car in the summer it's worth it. The parts cost me about $500 used from a guy over on navplus.us who had one for sale.
