    Active Member Two Rings 05audi's Avatar
    Oct 06 2005
    2005 Audi A4 1.8t
    U.S.
    Possible Transmission Issue, NEED ADVICE
    I got in my car last week and my check engine light came on. I did not really take notice of it until I put my car in reverse ( I have tiptronic) . When I gassed it, it reved up real high, almost like it was not catching, but when I put it in drive, everything was fine. The only thing that was funny was that all of the letters, P R N D S, were all flashing and the revs were acting a little funny. Has this flashing ever happened to anyone else, and what should I expect when I go into the dealership this week?
    Dec 06 2007
    Re: Possible Transmission Issue, NEED ADVICE
    ^^ tranny took a dump take and have it looked at immediately!
    -Kirk
    BetaAlphaTau Member #58
    Registered Member Three Rings
    Jun 21 2007
    Fort Lauderdale,FL
    Are you FWD or Quattro? If you are FWD, then your car is CVT equipped, if that is the case then the flashing gearshift indicator means your TCU ( transmission control unit) is screwed up. If your car is an 05 with under 50k miles, you should still be under warranty, just take it to a dealer.
    If you are quattro, i am not sure if it means the same thing, but most likely it does.
    Oct 06 2005
    2005 Audi A4 1.8t
    U.S.
    I have FWD CVT, and its under 50k so hopefully they can fix it
    Established Member Two Rings younga4's Avatar
    Apr 08 2007
    B6 A4 1.8t & MKIV 1.8t
    City of Angels
    Glad to see things worked out, see you soon.
    coalesce
    "We must find a new way to interpret our thoughts and feelings and reassess the extent to which our appraisal of our reality is realistic".
    Audentes Fortuna Juvat
    Young
