The blades are S4 actually bought on this site. I figured if i'm doing blades, go big. The rims are 18x8.5 front and rear and to answer the sidewall question, it's more of a consideration of the overall rolling diameter of the front tires versus the rear where the quattro drivetrain is concerned. There's good info on this subject on this forum if you search. Also this site helps to calculate for different setups:
http://www.1010tires.com/tech.asp. I had these tires from a gti that I had before with a staggered setup and it was a waste not to use the tires up. When the rears are shot, I will put on 235/40 on the back as the car already understeers. Maybe the RS4 sway will help. Thanks for the complements. I owe the look to many on here and A4mods for ideas and DIY's especially the DIY front USP lower with stock upper and the rear rebar mod. Thanks again.
