Results 1 to 8 of 8
    Senior Member Two Rings Widget's Avatar
    May 22 2007
    '06 A4 S-line, 2.0TQMT - Moro
    New England....
    Spacer bolt questions
    I just picked up a set of spacers and new bolts.* I've yet to pull a tire on my car.* Are these bolts like the reverse of lug nuts that I'm used to on american cars or do they mount into the hub somehow?* The weather isn't quite nice enough to go take it apart to look.*
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Re: Spacer bolt questions
    There are threaded holes in the hub, and you simple screw your lug bolts into them. The spacer will simply sit between your wheel and your hub. Your hub and oem wheels should be hubcentric, meaning there will be a small lip to set/center the wheel on, but it doesn't hold the wheels there perfectly without lug bolts.
    1. Take off your wheel
    2. (optional) Apply some antiseize to the back of the spacer if you have some and want to. This will help with the uninstalling of your spacers, and they will get stuck on the hub due to weather and elements.
    3. Line up the correct holes on the spacer, and push the spacer against the hub as good as you can by hand
    4. With rubber mallet (soft so it doesn't harm the alloy spacer) hit the spacer around the center to seat it. When it's on there good, hit the outside edges a little harder (in kind of a star pattern) to make sure spacer is all the way flush against the hub. If the spacer is not on there all the way, it will probably cause vibration issues.
    5. Set your wheel on there (I like to lower the car so the hub is level with the wheel so I don't have to lift it up) and thread in your new lug bolts by hand. Any order is fine since you're just threading them in partially.
    6. With the wheel in the air begin to torque your lug bolts down in a star pattern to 88ft/lbs a piece with your torque wrench. If the weight of the car is on the wheel, it might not be perfectly centered. Same for if you tighten in a circle pattern and not a star. This can also cause vibration issues if you do it wrong.
    7. Lower the car back down, and check each lug again with your torque wrench just to be sure.
    8. Re-check your lug bolts after you drive around for a day or two.
    DISCLAIMER If you do any damage to your vehicle by following my instructions, feel free to sue me for as much as you want. This is the internet and I will deny your allegation and you will just lose money while I post a thread about it and the internet laughs at you
    Ignorance is bliss.
    May 22 2007
    New England....
    Thanks.
    Jan 24 2007
    Wisconsin
    Any time, brother
    Ignorance is bliss.
    May 22 2007
    New England....
    Think I can run 38mm bolts all the way around.* 8mm/10mm spacer setup.
    Jan 24 2007
    Wisconsin
    28mm is the oem lug size. 38mm will be perfect for 10mm spacers, and they should work fine for 8mm spacers as well. I'm very confident they wont hit the rotor, but be very careful and listen when you first roll/drive away just to be sure. You shouldn't have any problems though.
    What wheels are these going on, did you buy the correct seat lug bolts too?
    Ignorance is bliss.
    May 22 2007
    New England....
    Just spacing out the stock S-lines for now. (ball seat right) I'm planning on picking up some RS4 reps. Just can't decide if gunmetal will work with the Moro Blue. I love the gunmetal wheel, but am leaning towards chickening out and doing hypersilver.
    Moro Blue Photo Thread
    WTB: | Stasis SS coilovers | 19" Gunmetal RS4 reps PM me...........
    Jan 24 2007
    Wisconsin
    Stock wheels will have the ball-seat lug bolts, but I'm not sure about the RS4 reps since they are aftermarket... they might require conical lug bolts.
    Ignorance is bliss.
