Results 1 to 10 of 10
Thread: Brain storm
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Brain storm
    I just had an idea. I'm sorry if this is a repost or has been looked into already. If anyone has seen or would know how to do it I think this would be a pretty sweet idea.
    I've been reading a lot on the different gauges, boost, oil pressure, A/F mix, etc. And there really isn't a stock looking location that one can be mounted.
    The vent gauge looks about as close as one can get.
    What If we could somehow make it so that the various readings were digital and in the notification center. you know, where the radio and outside temperature and the trip calculator is. This way you could have multiple readings all on one screen and you could change the readings using the same way you change the trip calculator.
    The challenge is, can it be done?
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    Re: Brain storm
    sounds really hard. you should try it on your car and get back to us.
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Apr 06 2007
    Pittsburgh
    Re: Brain storm
    I'd love too but I wouldn't know where to begin. I guess you'd need the various sending units and somehow get it to the ECU...
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Brain storm
    First off, the WHOLE point of a boost gauge...technically...is to have it all analog. Digital aint shit. When you have a analog boost gauge (with needle) you can observe how your engine is running, by just simply seeing how the needle is reacting, to both vacuum, boost, etc. By having a digital gauge you are defeating the purporse.
    -Sami-
    Dec 06 2007
    Re: Brain storm
    idea is there, i'd rather have one retrofitted into my cluster to look sort of like my fuel gauge!
    -Kirk
    BetaAlphaTau Member #58
    Apr 06 2007
    Pittsburgh
    Re: Brain storm
    I only thought of this because of the boost gauge in the mirror. I'm pretty certain that you can get the same info regardless of the read out. The only problem with a digital read out would be if your electronics crap the bed.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: Brain storm
    Yeah, I dont know why someone hasn't done it yet. Volvo tuners have do this a while ago.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    Re: Brain storm
    there is something that is very similar to what you have been talking to but it is for Passats, I don't think there is any reason that it couldn't be done for our cars. The only down side is they have been having some trouble with them so far. check it out http://www.sincityeuros.com/phpBB3/v...st+gauge#p7489
    WTB K04 turbo ASAP
    http://etektuning.com
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    Re: Brain storm
    i dont know, the digital gauge i got from Winston works great. i dont understand what you mean, the digital one reacts to vaccum, and boost as well. it actually reads vac so good that it will flutter between 19-20 when im idling. it seems if it sucked it would just kind of round up or down.....however, i am a total noob so if you could elaborate a little more as to why digital sucks so bad im all ears.
    Apr 06 2007
    Pittsburgh
    Re: Brain storm
    Well if they have one for another VAG product I'm sure one for Audi is coming soon.
    EDIT: Actually it looks like the have one for the A3...
