Results 1 to 30 of 30
    Registered Member Two Rings
    Feb 21 2008
    Rahway, New Jersey
    Putting s4 bumper on my 96. Sitting a little low under headlights.
    It seems everything is snapped in and the bumper is on safe but it is sitting low under the headlights and under the grill. Is there anything I am forgetting? This happen to anyone else?
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    Re: Putting s4 bumper on my 96. Sitting a little low under headlights.
    Did you put in the 2 like 6 inch bolts in from underneath?
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Fore-aft alignment is achieved by adjusting the bumper with the 2 long vertical M8 bolts loosened, then tightening.
    I used a 10mm in-hex socket (or 10mm allen key) from underneath to adjust once the bumper had loosely been fitted.
    from AW, helped me
    http://www.audiworld.com/tech/ext46.shtml
    2004 Subaru Impreza WRX
    Aspen White
    Feb 21 2008
    Rahway, New Jersey
    I dont quite get the adjustment part. Are you tightening something with that 10mm or what? Can you let me know exactly what you did?
    Aug 13 2007
    Quote Originally Posted by PCVET View Post
    Yeah i didnt exactly get it at first when i did mine either but when the bumper is off (maybe you can do it with it on? not sure) take a 10mm allen and right where the bumper bolt goes, it will fit it. Turn it until you see it going up, i had to move my drivers side about 1/4 of an inch up until i was happy..hope that helps
    Aspen White
    Veteran Member Four Rings jbrentd's Avatar
    Oct 31 2005
    '13 allroad, '91 Coupe Quattro, '64 Corvette, '93 Corvette, '21 Bronco
    Tulsa, OK
    TJ: Are there similar adjustment points on the rear bumpers? Also, how much are used S4 bumpers going for these days?
    1991 Coupe Quattro - Project Car
    2013 allroad - My DD
    2011 A3 S-Line - Son's DD
    SOLD - 2007 A6 4.2L // 2001 Pelican A4 Avant // 1996 A4
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2019 RS5, 2014 SQ5,
    LI, NY
    So did you buy new bumper shocks or did the stock ones work?
    Oct 30 2006
    B8 A4 Avant 6spd
    You need facelift bumper shocks to make the gap go away.
    -18 718 GTS
    Feb 21 2008
    Rahway, New Jersey
    why do i need facelift bumper struts? I think I have seen 96's mount them right on.
    Any the dude who posted that pic and writeup. Does turning those screws make the struts go up some how? How did it work out?
    Oct 31 2005
    Tulsa, OK
    I read somewhere that the pre-facelift bumper shocks are shorter.
    Feb 21 2008
    Rahway, New Jersey
    Quote Originally Posted by BONFIRE074 View Post
    Do you just tighten that One bolt? or do I have to tighten all three of them?
    Senior Member Two Rings al3x's Avatar
    Oct 08 2007
    Norway
    My S4 bumper sat waaay down even though it was attached on the sides. But when I tightened the bolts it moved up into the correct position. Don't know if that works for you though.
    I have the pre-facelift bumper shocks.
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Quote Originally Posted by jbrentd View Post
    Pre and post facelift A4 bumper supports are EXACTLY the same. Same part numbers from '95 - '01.
    There are only 3 different ones on the B5 platform:
    A4 pre and post facelift
    S4 pre and post facelift
    RS4.
    Aug 13 2007
    no you dont tighten/loosen the 3 torx that go to the radiator support. you take a 10mm allen and where the two bumper bolts go, you put the allen under there, you start turning it and it will either go up or down, in your case make it so it goes up and you should be all good. sorry it looks confusing in the pic
    Aspen White
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    so Siena, in two weeks when I throw my s4 bumper on my 96 2.8, I shouldn't have to replace my bumper shocks? Just perhaps realign my supports up/down? That would be excellent.
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by Siena View Post
    RS4.
    When i got my s4 bumper on the pre facelift bumper shocks were 1/2" too long. I had to buy post facelift bumper shocks. Bumper sits perfect now.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    I have been told that the US spec A4's have a slightly longer front bumper but I'm not sure how true that is and I can only think the S4 bumper is the same as the Euro spec S4 bumpers.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Feb 21 2008
    Rahway, New Jersey
    Where are the two bumper bolts? What will go up or down? In the picture there are three bolts and it looks like someone is tightening them.
    Feb 21 2008
    Rahway, New Jersey
    I still dont get what to do to raise my bumper. Alot of people on this thread have said that something has worked for them, but between these pictures and all the different responses I still can't figure out what to do.
    Aug 13 2007
    the two bumper bolts that you unscrew to remove the bumper. in the front. underneath you can fit a 10mm allen and it will raise it up.
    Aspen White
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Quote Originally Posted by docurley View Post
    I'm pretty sure you're right; the ecode bumper is shorter and doesn't have washer caps?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Oct 02 2006
    So. Maine
    Poopie: What were the part numbers on those "Post-facelift" bumper shocks if you can recall man.
    Jun 04 2004
    fairfield cnty, CT
    there doesn't appear to be any "pre" and "post" facelift bumper supports, correctly stated by Siena:
    To the original poster:
    did you even click the link to Audiworld in the 2nd reponse? This pic seems pretty clear to me:
    Oct 02 2006
    So. Maine
    Modified, good info there. This should clear up some of the people (Like myself) That keep getting told otherwise. It's kind of confusing actually, some people tell me I need to buy the shocks, others say it'll bolt right up.
    "there doesnt appear to be any "pre" and "post" facelift bumper supports, corectly stated by poopie:"
    You must be talking about Siena because Poopie quoted him.
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by 00SantorinS4 View Post
    thanks, and you're right, ill update my post :)
    Feb 27 2005
    North Wales, PA
    well there are definitely 2 types of bumper shocks. I was just as skeptical as you but when i stopped by the body shop, the manager showed me the two and they were definitely different. Since the insurance estimate didn't include bumper shocks i had to front the cash myself.
    Feb 27 2005
    North Wales, PA
    I believe there is an A and a C version.
    Jun 04 2004
    fairfield cnty, CT
    Quote Originally Posted by Poopie View Post
    there sure is...from my pic above "a" = canadian S4 and "c" = USA S4.
    NEXT![O_O]
    Oct 02 2006
    So. Maine
    Ok, I just slapped an S4 bumper on my 96, no issues what-so-ever.
    Guess it's a gamble whether or not it'll work on a prefacelift
    Feb 21 2008
    Rahway, New Jersey
    I tightened those 10mm allen holes and my bumper sits perfect :) 96 pre facelift
