Results 1 to 7 of 7
Thread: flex joint
    Senior Member Two Rings itsbigj05's Avatar
    Nov 28 2007
    ducati 696 and mg midget
    Pittsburgh
    flex joint
    The PO of my car installed a borla exhaust, and a few days ago I noticed the braided flex joint is all torn up and it's causing a huge exhaust leak. I searched a few things and found that those commonly rust out, and I was wondering if it would be alright to have an exhaust shop cut the flex joint out and weld on pipe in its place.
    If that's not an option, do you know if it's held on by clamps, or is it welded on?
    Thanks
    Established Member Two Rings Jagaer's Avatar
    Sep 30 2007
    2001 VW Passat 1.8T
    Re: flex joint
    I got mine cut & rewelded for $70 at a local muffler shop.
    The dealership wants to change the entire pipe with the flex joint, and the pipe alone is over $100 not including labour.
    I own a budget Audi...VW. Anyone want to give donations?
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: flex joint
    That happened to me. I took it to the muffler shop and a $140 later it was fixed. All the guy did is cut the flex pipe off and welded a straight pipe on.
    Nov 28 2007
    Pittsburgh
    Re: flex joint
    Thanks guys thats all I needed to know!
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    Re: flex joint
    whats the flex pipe for anyway? engine vibration?
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    Re: flex joint
    the flex pipe is pretty much needed on our cars due to the amount of drivetrain movement... I wouldnt stick a piece of solid pipe in there.
    You can get stainless flex sections online, like summitracing.com and a bunch of other places... get a new one and have a shop weld the new one in place... or you could use a pair of band-clamps and do it yourself.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    Re: flex joint
    i got it replaced at a local spot for 75 bucks. new flex joint and welding included in that price.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
