Results 1 to 19 of 19
    Registered Member Two Rings warning's Avatar
    May 06 2007
    Los Angeles, CA
    Making my car more economical - suspension questions with PIC
    Hey guys. I have a 2002 Quattro 1.8t. I switched my stock suspension to a Billstein shocks and Neuspeed Race springs about three years ago. I also have 19" wheels. I'm pretty much tired of the dumped look, tired of tires wearing so fast on the inside, and would also like to get better gas mileage.
    I was thinking about changing my springs to an aftermarket sport spring or put the stock sport springs on. Which would you guys recommend? How much lower are after market sport springs compared to the factory sport spring?
    2002 Audi A4 1.8 Quatro
    2003 Yamaha YZF-R6
    1998 Suzuki GS500
    WSMC #719
    CMRRA #719
    BANNER
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Re: Making my car more economical - suspension questions with PIC
    just get 17s. a stiffer suspension should give you better gas mileage and better life of your brake pads.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    yeah you should just get a set of coilovers ... then raise your car up to the height you like, and one which you can get a proper alignment
    keep your 19's
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    May 06 2007
    Los Angeles, CA
    Quote Originally Posted by martini View Post
    keep your 19's
    Hmmmm... let's see. Put on my stock sport springs or spend over 1k on coilovers. I just want the car to be more economical without spending so much to attain it. The car is getting old and would like not to spend so much money on it. I just want to know if a sport spring will attain my goal. Thanks for your response.
    2003 Yamaha YZF-R6
    1998 Suzuki GS500
    WSMC #719
    CMRRA #719
    BANNER
    Sep 20 2004
    Paradise Valley, AZ
    id leave the suspension set up the way it is. the 19's are not helping your gas mileage and 19 inch tires are sooo expensive. i think sport springs and smaller rims would solve your problem.
    May 06 2007
    Los Angeles, CA
    Quote Originally Posted by diztek View Post
    Sweet. Thanks diztek.
    Question. Should I get an aftermarket sport spring or slap on the stockies?
    2003 Yamaha YZF-R6
    1998 Suzuki GS500
    WSMC #719
    CMRRA #719
    BANNER
    May 24 2007
    Southern California
    if i were in your shoes. i would get smaller wheels. but if you dont like the drop
    anymore, go with the stock sports.
    Kyle
    2.0L Revo GTRS Eliminator
    Sep 20 2004
    Paradise Valley, AZ
    sounds like you are into saving money. id just slap on the stock sport springs.
    Veteran Member Three Rings d_maniac's Avatar
    Sep 16 2006
    99.5 A4 1.8T Q, 2004 A4 1.8T
    Bronx, New York
    i would get the sport springs, also what wheels you running?
    Dec 19 2007
    York, PA
    wow, your wheels are tits, what are they?
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    I'd say suck it up and leave the car the way it is, cause the shit looks tiiiight! Do you really think changing your wheel size and or suspension set up is going to affect your gas milage that much? ... I don't
    May 06 2007
    Los Angeles, CA
    Thanks guys. I think I'm going to go with the stock sport springs, if I could find them in the garage somewhere.
    The wheels are Axis Milanos. 19x8.5 front and 19x9.5 rear.
    2003 Yamaha YZF-R6
    1998 Suzuki GS500
    WSMC #719
    CMRRA #719
    BANNER
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    how about getting usp springs
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Feb 17 2005
    Sarasota, FL
    Tire wear should not be affected much by lowering the car if your alignment, specifically toe, is correct and to spec
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by yung turbo View Post
    USP Springs are the same as the 03-05 Sport springs. The only "OEM" spring that is lower is the Sport spring from an 02'
    Established Member Two Rings busakiller's Avatar
    Dec 18 2007
    Pittsburgh,PA
    Quote Originally Posted by A4ringedONE8T View Post
    What do you think the difference is between the yrs.. Can't be that much of a difference.. 02 = inch drop compared to 03-05 .75 drop??????
    May 06 2007
    Los Angeles, CA
    Quote Originally Posted by busakiller View Post
    Crap. I can't find my stock springs. I might have to look in the classifieds, CL, or ebay.
    I didn't know that the sport spring for 03-05 was not as low as the 02. This is good information. Thanks.
    Do you guys know if an 06 sport spring will fit my 02?
    2003 Yamaha YZF-R6
    1998 Suzuki GS500
    WSMC #719
    CMRRA #719
    BANNER
    Veteran Member Four Rings aaron1085's Avatar
    Jul 12 2007
    2007 2.0T A4
    NH
    great wheel combo...
    get some light weight 18's on there with STOCK sport spring set up.
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    I love those wheels!
