Results 1 to 6 of 6
    Feb 01 2008
    Coolant temp problems
    I am having a problem with my coolant temp. If the car is sitting idling it will go to the middle mark of the gauge. Once i start driving the gauge needle will drop. If i sit at a traffic light it will start to creep up. What do you guys think the problem is. I replaced the temp sensor.
    Thanks in advance
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: Coolant temp problems
    it's supposed to go to the middle. Just not past it. if you drive you have cool air being drawn in which cools it down a bit, thats all your noticing.
    Even though Mine does go past the middle line, I think my after run fan is dead. Anywyas I woultn worry to much.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Thermostat is broken. I have same problem. I've replaced my temp sensor 3 times (this being the fourth sensor) and it still doesn't work. It throws a CEL when I use heater, telling me either Thermostat or Temp Sensor is broken. When I use heater the needle just stays 'down' and doesn't move.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    I've noticed that after I shut my car off after driving, if I turn the ignition on and get the gauges to turn back on, the coolant temperature is past the middle mark. When the car is actually on and running, coolant temps are right at the middle.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    thermostat is stuck in the open position and is not able to regulate the water flow, too much flow =cooler temps.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Dec 06 2007
    Calgary, AB, Canada
    ^^Agreed. Sorry bud, but it's time for a TB/WP/t-stat job.
