Results 1 to 23 of 23
    Senior Member Two Rings Greg9's Avatar
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    blown 2 coilpacks in 2 days
    On friday i got what felt like a blown coil pack and a cylinder number misfire code. I replaced it with one of the tow spares I had in my trunk. When I cleared the cel it didint come bak on and everything seemed to be normal.
    Lastnight that one I just replaced went again. Same thing and same code. It wasint a new one it was a used one that I saved when I had all 4 replacedabout a year and a half ago.
    Has anyone had anything like this. Maybe the conector that plugs into the coil is shot? I need to use the car today and I dont have a cel and its running good right now I also dont have any more spares.
    I was thinking that that one I put in was maybe not in that great of shape but when the dealership replaced all 4 last year and have me the two best for spares that maybe they mixed them up and gave me one that wasint that great.
    "DRIVE FAST & TAKE CHANCES"
    White B7 A4 w/ Titanium package, APR Stage 1, APR downpipe w/ High flow cat!, NGK Iridiums, ECS Underdrive Pulley, Stoptech rotors & pads w/ ECS stainless steel lines, Meyle HD Front Control Arm Kit & rear sway bar links, Bilstein B8 Shocks, 034 Motorsport 25mm rear swaybar, 034 Motorsports Street Motor Mounts, ECS Snub Mount, ECS Rear Differential Carrier Mount Bushings Insert Kit, Forge Atmospheric BlowOff Valve, ECS Throttle Body Hose, AEM air filter kit.
    Dec 06 2007
    Re: blown 2 coilpacks in 2 days
    ^^ i had the same issue, i changed my coilpacks with 4 slightly used ones off the same car, and the week after all 4 were blown! but check and see if u see any damage to ur engine wiring harness! mine looked like it had been eaten by a rat up front and caused me to go through 2 complete sets of coils and plugs!
    -Kirk
    BetaAlphaTau Member #58
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    My money is on conincidence....just buy a new one and go from there
    -Sami-
    May 16 2007
    Westminster, CO
    I think it may be best to replace all of the packs once any one of them goes bad. Keep the good ones for emergency only, they don't seem to last long once one goes out.
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    where is the best place to buy CP's?
    19' Glacier S4 Black Optics
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    so how often are you guys changing your cp's. I put the whole new set of 4 in about 14 months ago.
    Aug 26 2007
    just blew my 1st one today since i had the car (august)
    Buncha motorcycles
    Memphis, TN
    hitachi E's filo.... gamiseta, gafiseta
    APR Stage 2/AWE Intake
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    The ones in the car I was told by the dealership that they were the new updated kind that will last longer and not even 15 K later one goes out. Not to mention the charged me like 300 somthing. Ill prob order the hitachi E's that papachristou seems to like. Hope there better than the Bremi's.
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    Just got some for 112.21 including shipping from
    audipartssuperstore.com
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I've been running the Hitachi coil packs for over a year now with no problems.
    Dec 06 2007
    ^^ i payed $25 each for mine, brand new and they were delivered to me!
    -Kirk
    May 24 2007
    Southern California
    Quote Originally Posted by Greg9 View Post
    jeez 300 bills. i paid under 100 for 4 at the dealer. beru r's
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Three Rings PRVWing's Avatar
    Jan 18 2005
    Puerto Rico
    I had the revision L for a year and a half with no problem, blew one and changed it another revision L i had spare. But i'm thinking of buy a new set of the R's... how good are they? anyone with good/bad experience?
    FlexTuning
    White USP A4 1.8TQ6MT
    K04, 380cc injectors, GIAC Reflash, HKS BOV, PSi TP, Milltek exhaust (with Magnaflow mufflers), AWE FMIC, Samco TIP, Neuspeed snub-mount, Neuspeed Power Pulley, Stratmosphere short shifter, Stratmosphere clutch, B6 S4 front and rear brakes, stainless steel brake lines, RS4 19'' reps, RS4 rear sway-bar. NEW Bilstein Sport Shocks, and H&R Sport springs!
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Stupid stealership by me charges $55 a piece. God I hate that place.
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    Heres a question for you guys...is anyone running 06C-905-115-L coils. I guess they are the same as the "R"s but the have a nice red top. Its wierd tho because esc only lists them for the 3.0 but a couple others list them for the 1.8 also and say that they are the same as the "R's" so they will work in any car that uses the R's. Anyone?
    Senior Member Two Rings lfloodt's Avatar
    Feb 18 2008
    Black '05 A4 Avant 3.0Q 6speed
    philly, pa
    woke up today and started my car, car was running rough. sure enough, 30 seconds later it's the flashing CEL! i parked it and I'm waiting until audi service opens for the day(still under warranty.) this will be my 3rd coil pack since buying the car used on dec. 29th. i don't know the technical detail of coil packs, mine have the red top.^ car is a '05 3.0Q Avant
    '05 B6 Avant/6 speed/3.0Q / De-cupholdered armrest....
    Feb 18 2008
    philly, pa
    update from earlier^-- dealer took my car in right away and replaced all coilpacks under warranty. hopefully I'll be good for a while........
    Sep 23 2006
    Houston TX
    strange, haven't heard of many 3.0 coils going bad. I've never had a problem and my car is '02. guess as long as you didn't have to pay, doesn't matter.
    I know many people have said 3.0 and 1.8T coil packs are different. They may work, but for the cost probably not worth it.
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    just blew an "R" coil last night... car was running smooth and boosting strong, all of a sudden i climb a small hill and car starts chugging... i had to replace it with a stock coilpack i had in the trunk from when i replaced all cp last summer (7 months / 8000mi.) its funny, cause the stock cp lasted about 50k mi.
    you should buy those coilpacks... and shove it up their overpricing asses. then go to ECS and pay 1/3 the price
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I have had only one go at around 88K miles, not to say it didn't have all new put in when I bought the car CPO at 47K. I just recieved my new "E" stlye stage III kit from ECS, $235 in preperation for GIAC
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Could be worse. I blew 2 in one day.
    Apr 09 2007
    1965 AC COBRA
    Syracuse, NY
    So nobody is using these on there 1.8?
