Results 1 to 7 of 7
    Registered Member Two Rings john doe's Avatar
    Mar 07 2008
    2001.5 s4 Pearl White
    pa
    diy s4 turbo install questions
    what are my fastest options for installing both turbos at once ? i would think pull the motor , but how , out the front out the bottom , etc . and back together , best way
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: diy s4 turbo install questions
    If you have a lift, then going form the bottom is prob easier. If Your doin this in your garage you need to remove it up and out of the bay, No need to remove subframe. Probably easier to remove with the tranny together as apose to removing the tranny before hand. And back togetehr exactley the oppisite way you took it out. GL
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Mar 07 2008
    pa
    would subframe mounted to the motor and install from front be eazyer . (i do have a lift)
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    i dont think this has ever been discussed
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Quote Originally Posted by XJinCT View Post
    hahaha. I've never done it but I would say it would be quickest to drop the subframe with everything on it (engine & tranny).
    the homebrew'd s4
    Mar 07 2008
    pa
    ok ok ok this was an honest question
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by john doe View Post
    search through my old posts from like 2-3 months back i did a COMPLETE write up with like 400 pictures of how to do a turbo swap....Please search next time, this topic, along with every question you have has been beaten to death 23132412343243243 times. GL
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
