Results 1 to 7 of 7
Thread: F-hose concern
    Veteran Member Three Rings ms4cd's Avatar
    Mar 23 2005
    Slow buckets
    F-hose concern
    I do not seem to understand why my F-hose has oil residue on it? I am positive that it does not leak yet every time the car is driven I see this:
    Mar 23 2005
    Slow buckets
    Re: F-hose concern
    No one?
    Veteran Member Three Rings ToMMyRsK04's Avatar
    Dec 26 2006
    2000 audi s4
    New York
    Re: F-hose concern
    sick garage in your avatar
    bye bye AWE Stg 3+ and HeLLooOo ........
    For Sale
    - VAST Port & Polished Intake Manifold - BEST OFFER
    - Stock B5 S4Pistons/Rods/Valves/Springs/Retainers/Cams 44k on them
    - Two GT3076 Turbos
    Veteran Member Three Rings Dowskeet's Avatar
    Aug 10 2007
    Re: F-hose concern
    Quote Originally Posted by ms4cd View Post
    There doesnt look like there is alot of oil on the F-Hose to me at least. Is there any oil residue on the motor? Maybe there is an issue with another part and that is just blowing oil on the f hose? Maybe a headgasket?? Or the intake manifold gasket has found a little spot and some residue has come out a little..
    Cheers
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Re: F-hose concern
    honestly i cant see much residue in that picture
    I agree with you about the enigma.. when I replaced my f hose, which was very covered in residue..I could not find a single hole!? I dont know what pressure the oil is going through there?
    Perhaps if it is high enough pressure wise do you think maybe its shooting out from the end points a little?
    Mar 23 2005
    Slow buckets
    Re: F-hose concern
    Quote Originally Posted by Dowskeet View Post
    Cheers
    Well let me be more clear. Every time I drive the car there is an oil film on the samco hose, I wipe it down with my hand and it's oil for sure. I realize there is about 25 psi going through there but no other hoses feel wet such as this one.
    I guess question would be if anyone else has noticed that. Especially the stage 3 people.
    I certanly hope it's not the head gastket, the car runs good and there is no coolant leaks.
    Dec 06 2007
    Calgary, AB, Canada
    Re: F-hose concern
    Is there any oil residue around your cam gasket? To answer your question, I haven't notice any oily residue on the F-hose on my car. I would suspect that unless you are getting blow-by and there's a leak in the hose, you are probably just getting some oil spray from a leak somewhere in the cylinder head nearby.
