Results 1 to 6 of 6
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 04 2005
    14 MkVI, 11 Sienna AWD
    530, California
    01 1.8t/awm Have ICM?
    I have a major misfire problem, replaced all four coil packs last month anlong with new bkr6e's and life was good, all the sudden I get a cel for lean condition, find some vac leaks, clean maf and clear code. As soon as I fire it up it starts misfiring, I then switch to the bkr7e's and still the same blinking cel. Does the 01 have an ICM I can swap out, ECS doesn't seems to have one:
    http://www.ecstuning.com/stage/edpd/...ory=Electrical
    My misfire thread:
    http://www.audizine.com/forum/showthread.php?t=199261
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    Re: 01 1.8t/awm Have ICM?
    icm was only found on drive by cable cars ..well, 1.8t cars anyways
    contact via email please.
    Senior Member Two Rings a4_1.8t_01's Avatar
    Feb 24 2008
    A4 1.8TQM 01
    No ICM... A bad enouch vac leak will cause a missfire. Check every hose.
    Unitronic tuned. love it.
    Need any services done in NYC area please PM me. I will diagnose and fix your car. Also do clutch replacements, Timing-belt services, Turbo upgrade/installation, Fluid changes, boost leaks and pretty much anything.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Check the L hose thats to the right of the intake manifold. My 01 had a tear in it and misfired like whoa even at idle.
    Jan 04 2005
    530, California
    Will maybe do a smoke test and or a boost leak test help?
    I will look for MORE vacuum leaks.
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
    Jan 04 2005
    530, California
    Did a throttle body calibration, cleared code and :)
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
