car was a wrecked bad 4 months ago
Saturday,29,March,2008,18:37:14:01133
VAG-COM Version: Release 704.1
Data version: 20071016
VIN: WAUJC68E22A272767 Mileage: 110200km/68475miles
Address 01: Engine Labels: 06B-909-518-AMB.LBL
Part No SW: 8E0 909 518 F HW: 8E0 909 018
Component: 1.8L R4/5VT G 0001
Coding: 0016501
Shop #: WSC 78900
10 Faults Found:
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal
17880 - EVAP Leak Detection Pump: Short to Ground
P1472 - 002 - Lower Limit Exceeded - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 002 - Lower Limit Exceeded - Intermittent
17843 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded - Intermittent
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 002 - Lower Limit Exceeded - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 002 - Lower Limit Exceeded - Intermittent
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 002 - Lower Limit Exceeded - Intermittent
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 002 - Lower Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04275
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 AG
Component: A4 Klimaautomat 1424
Coding: 00010
Shop #: WSC 05127
1 Fault Found:
01593 - Heated Windshield (Z2)
36-00 - Open Circuit
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
No fault code found.
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655 A
Component: Airbag 8.4E 5000
Coding: 0010607
Shop #: WSC 63351
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00041
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 950 H
Component: KOMBI+WEGFAHRS. RB4 D26
Coding: 02200
Shop #: WSC 05141
WAUJC68E22A272767 AUZ6Z0B0052604
Address 45: Inter. Monitor Labels: 8E0-951-177.LBL
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 T
Component: Komfortgerát T5B 0619
Coding: 11788
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
9 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01034 - Electric Window Thermal Protection Active; Driver
01801 - Door Warning Lamp; Drivers Side (W30)
57-10 - Electric Circuit Failure - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
00912 - Window Regulator Switch; Front Left (E40)
00915 - Window Regulator Switch; Rear Right; Driver (E55)
01562 - Right Rear Door
59-10 - Can't Unlock - Intermittent
Address 56: Radio Labels: None
Part No: 8E0 035 195 A
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 00000
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
44-10 - Short Circuit - Intermittent
End
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Coding: 0016501
Shop #: WSC 78900
Readiness: 0110 1100
Coding: 04275
Shop #: WSC 06435
Coding: 00010
Shop #: WSC 05127
Coding: 00003
Shop #: WSC 63351
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 0010607
Shop #: WSC 63351
Coding: 00041
Shop #: WSC 63351
Coding: 02200
Shop #: WSC 05141
Coding: 11788
Shop #: WSC 63351
Part No: 8E1959801B
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
Coding: 00201
Shop #: WSC 00000
