Results 1 to 8 of 8
    New Member One Ring
    Mar 29 2008
    2004 Audi A4, 2001 Mazda Miata
    rear blinker bulb
    I have an 04 A4 Avant and one of the rear blinkers went out ... thinking that this was a simple bulb replacement, I went to remove the exterior lens but can't figure out how to do it - no external fasteners and looks completely sealed. Can someone tell me how to get the lens off? I really don't want to pay my dealer 50 bucks for a bulb replacement.
    My apologies if this has been answered somewhere else - I searched around a bit but did not find anything.
    Mar 14 2008
    Tennessee
    Re: rear blinker bulb
    Your car may be different, but I access rear bulbs from inside the trunk of my 96 a4.
    Senior Member Two Rings lfloodt's Avatar
    Feb 18 2008
    Black '05 A4 Avant 3.0Q 6speed
    philly, pa
    there's one screw holding the housing in, it's located behind a little removable cover on the inside of the car about half way up the tail light. unscrew the screw and then roll the taillight assembly away from the car(that's the best way I can describe it.) the whole thing comes out as one piece and then you can replace the bulb. it's a little hard to pull the assembly out, but it's definately only the one screw. and be careful not to let the screw fall in down behind the trunk trim.
    http://www.audizine.com/forum/showth...ant+tail+light
    '05 B6 Avant/6 speed/3.0Q / De-cupholdered armrest....
    Senior Member Three Rings SportSter's Avatar
    Jan 28 2008
    Silverado 2500 TD 2005 Audi A4
    San Diego
    guys this is an avant, and my memory may be failing me but when I went to fix my brothers it didnt have our little flip out circle with the screw. I dont know how to get that tail light off. best of luck, my brother finally took it to the dealership...
    2005 Audi A4 1.8t Quattro 6spd
    Stassis Suspension, H&R Sway Bars, Revo 1, Upgraded Front Brakes, s/s brake lines. More to come!
    1999 Silverado TD (597 lb TQ @ 32lb boost), Upgraded Turbo, Mechanical Waste Gate, Heath chip, front mount inter cooler, cold air snorkel, 4" straight pipe exhaust, 3.5" down pipe, upgraded injectors, pump, and lift pump, PMD Isolator, twin thermostat cooling system, 130 GPM water pump, Pillar Gauges, 3" body lift 35" tires.
    Feb 18 2008
    philly, pa
    yeah my car is an avant and so is the one in the thread i listed. you should be fine....
    Veteran Member Four Rings dubenvy's Avatar
    Oct 21 2006
    '14 A4 2.0tQ (wifey)
    Odenton
    Check to make sure your blinker fluid is topped off...other wise you are wasting your time
    USP CLUB MEMBER #41
    <<Insert Clever Signature Here>>
    Feb 18 2008
    philly, pa
    ^lol and your manual blinker adjustment module should be set to .053
    New Member One Ring
    Mar 29 2008
    Thanks ifloodt - I didn't even notice the removable cover on the inside, but that was exactly right ... bulb replaced - $2.15 at my local auto parts store.
