    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    shutters and no power
    I was dropping off my girlfriend and the car was stumbling and not running well. It was almost stalling then the CEL started flashing went away, then came back. Also got a service engine light. I vagged these codes
    3 Faults Found:
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 001 - Upper Limit Exceeded
    16688 - Shareware Version. To Decode all DTCs
    P0304 - 001 - Please Register/Activate
    17658 - Shareware Version. To Decode all DTCs
    P1250 - 008 - Please Register/Activate
    Coil packs, spark plugs (semi recent replacement), what else?? What else do i/can i check??
    barrett
    2019 SQ5 Prestige
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Re: shutters and no power
    sounds like coils packs to me... did you change all coil packs recently?
    2004 Audi A4 1.8T Quattro 6-speed
    • Bilstein PSS9 • APR Stage 1+ w/ TT225 Injectors • Forge 007
    • JHM SS • Oettinger RZ 19x8.5 • Podi • RS4 Rear Sway
    Dec 06 2007
    looks like a software problem? i would check ur coilpacks, i changed all four and the week after 3 went out, i had a tore up engine wiring harness, so check them again!
    -Kirk
    BetaAlphaTau Member #58
    Apr 01 2007
    houston texas
    The car has 50K on it and as far as i know the coilpacks have never been changed. I got the car with 38K on it. How long do they normally last? Wheres the cheapest place to get them?? Which ones do i get??
    barrett
    2019 SQ5 Prestige
    May 24 2007
    Southern California
    fastest way. dealer. Beru type R. about 30 bucks each
    Kyle
    2.0L Revo GTRS Eliminator
