ok, i did some logging today. i logged '115' and according to vagcom im running 22.6psi and according to my boostguage im running 27psi, boost leak maybe? i keep turning up the wick on my mbc and cant get anymore then 22psi but yet my boostguage goes higher and higher! im guessing vagcom is reading the boost levels at the MAP sensor correct? and my boost guage reads boost at the fpr correct? so where is the boost leak? ive pressure tested numerous times! i know i have a leak at my mechanical cam chain adjuster gasket but thats after the map sensor. so whats up. by the way i ran two 3.55 fats and two 3.6 fats runs today.
