Results 1 to 3 of 3
    Veteran Member Four Rings jackyaudi's Avatar
    Jun 26 2007
    '02 A4 1.8TQS
    Montreal
    Turbo leak: how to check?
    On a previous thread, I was asking what are the possibilities to lose about 1 liter of engine oil within 2-3 months. I checked under the engine area, there was nothing. Someone mentioned to check the Turbo for leaks. Problem is I dont know how to check that, yet.
    Could someone direct me how to check if the Turbo has leaks which would cause eating the oil from the engine? Any picture or detailed steps will greatly help since I know almost nothing about Turbos (yet I have one)
    Car is 02 A4 1.8T
    oh, and thanks in advance for any help.
    Senior Member Two Rings BryMFL's Avatar
    Apr 20 2007
    '02 Audi 1.8T Quattro
    Winter Haven, FL
    Re: Turbo leak: how to check?
    I've got this exact issue right now. 1qt every 2-3 months and I got a visual on mine 3 weeks ago while doing timing belt job after taking off my front end I got about 1/4 cup oil in my turbo intake piping. You're gonna want to disconnect the inlet pipe coming from your turbo down to the front of the car(not at the turbo but at the front of the car) and if its anything like my you should just have to run your finger inside there and find the oil. The only thing you should need is a turbo rebuild kit from $45-85 depending where and what comes with it. My concern now is do I rebuild or just upgrade?!?!?!?!?
    "BryMFL"
    Bryan Meeks
    "Quattro- It's like having your very own roller coaster ride!"
    Mar 11 2008
    B7RS4 & e46Ms
    turbo seals... and you won't have any signs except around the inside of the compressor housing, intake track, and all vac/boost lines in-between. Start turbo-shopping with BryMFL...
