Results 1 to 11 of 11
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    Question Replacing all rubber/hose components, any inputs??
    i was looking around and seems like my car is loosing vacum and boost, since im deplyod overseas, i was wondering does anybody know how many feet of vacum hose do i need, and what do i need to replace all rubber connectors and all hoses in my car. I mean EVERYTHING that is rubber and function is a hose for ALL the systems. have anybody done that before or have any info?
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    Re: Replacing all rubber/hose components, any inputs??
    All i know is that it needs to be done because all that damn heat from the turbo and heat temperatures in general destroy all of the rubber hoses. I am not sure if there is an upgrade to use something else besides rubber??
    Oct 08 2007
    Columbus, OH
    ecstunning selling all kinda replacements, i just dont know how much i need and where are all of them go, obviously i can replace hoses that are on top but im sure there is way more hidden somewhere else. So far im set on buying turbo hoses by Samco, vacum line maybe 10 feet just in case, and breather hoses from ECS
    Established Member Two Rings bavaria75's Avatar
    Feb 13 2008
    02 A4 3.0QM - 04 Passat 1.8TM
    San Jose, CA
    I got the vacuum lines from VW dealer. ON my wifes 2004 Passat this are out of full rubber, not the cloth type anymore. Picked up 2 meter what was enough for a 3.0 engine.
    A little tip, always cut the old hose on the fittings and kind a turn them off to limit the risk of damaging your fittings. And do one hose after the other to prevent mixup.
    Should take you 2-3 hours if you take your time.
    Good luck.
    2002 A4 3.0 Quattro Manual
    Oct 08 2007
    Columbus, OH
    Thanks, i'll make sure to remember that when i get back, 2 meters is about 6-7 feet right?
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    I was thinking about doing mine...
    Let me know how it goes!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by golgo13 View Post
    Replace your vacuum lines with 100% silicon lines. The factory ones become brittle and crack. Silicon ones can withstand the heat. Try McMaster Carr.
    -Doug
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    Hmm. I was going to order 20' of silver 3.5mm SVH from hose techniques. Is that too much? It seems that 10' won't be enough and I'd rather have extra, even if it isn't the cheapest.
    I was planning on doing just the 3.5mm using zipties to hold it on. If anyone has some other sizes I can do at the same time, please post.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I know I remember posting about this before. Look what the search button revealed:
    For documentation purposes....
    If you chose to replace the vacuum lines yourself here is the stuff I used:
    100% Silicon 4mm Black vacuum line. 10ft at $2.00 a foot from Baker Precision Products http://www.bakerprecision.com
    I'm sure you can buy them somewhere else but this is where I bought mine from.
    OE-style hose clamps from McMaster-Carr (I love this place. Its like walking into the Sears tool department.) http://www.mcmaster.com
    Part Number: 52545K42
    Item: Gap-Free Pinch Hose and Tube Clamp 5/16" to 3/8" Clamp ID Range, 13/64" Band Width
    Package of 25
    $6.82 / package
    Part Number: 6541K69
    Item: Side-Jaw Pinch Clamp Pincer
    $21.94
    Prices as of July 2005. They may have changed since then. Part numbers are still current.
    and here's the thread:
    http://www.audizine.com/forum/showth...08#post2110108
    -Doug
    Feb 13 2008
    San Jose, CA
    As this are vacuum lines, you will not need to clam them nessesary. The original are not clamper either but a nice tight fit. as mentioned I got 2 meter (6 feet) of the silicon based from VW for approx. 15$/meter. Most of my longer lines are connecting to some solid plastic hoses, what seems to withstand the heat better. So yes if you intent to do all the lines out of one piece you will need suggnificant more silicon rubber lines.
    You can check the part list out on the below link. It also gives you an idea where the hoses go. You might need to sign up for it to see the drawing, but it's free anyway.
    http://www.vagcat.com/epc/cat/au/A4/...49/49/3126070/
    Nov 22 2006
    Thanks, dougyfresh. I pride myself on being adept at search strings but missed that one I guess - probably due to the thread title.
    Hmm, 4mm - ECS has the stock hose dimensions at 3.5mm. I doubt it will make much of a difference, though. I'll be using zip ties in lieu of the single-use clamps. Lastly, I came across that site for hose but flinched at the $ for silver.
    Thanks for the vagcat link, bavaria75. I already have an account so that was easy.
    I can't wait for some warmer weather.
    2002 A4 TQMS
