Results 1 to 13 of 13
    Feb 23 2008
    ko
    BAD Vibration + CEL just after HIGHWAY FUN
    Hi,
    My car has giac Fx k03 + 380cc, noting else. It's an 04 1.8TQTip. It's boosting real nice this morning, with plenty of power. While having some highway fun later on today, my car started to vibrate (engine) inconsistently. THen a CEL came on Flashing. About 1 or 2 miles later, I had a plain CEL. When the car is stopped and I rev the engine, it does rev very fine. However, when I put load on the engine, trying to forward or reverse, it studder badly, looks like it's shoking. No black smore or smoke at all. No weird sound.
    someone has a little idea what must have gone wrong ?
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: BAD Vibration + CEL just after HIGHWAY FUN
    Do you have a boost gauge?
    Are you sure you havent forced yourself into limp mode?
    Quote Originally Posted by mz3bo View Post
    Hi,
    Mar 27 2005
    The Cold North
    it could be something as simple as a coilpack on it's way out.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 23 2008
    ko
    Quote Originally Posted by audipotential View Post
    Hi,
    If I forced myself into limps mode, would'nt the car be running good until a certain RPM and then shut itself down ? Does the flashing then solid cel makes you thinks it has gone to limp mode ?
    Thanks
    Bo
    Feb 23 2008
    ko
    Quote Originally Posted by EBG 18T View Post
    In that case, is there a way to check if I don't have vag ?
    Thanks
    Bo
    Mar 27 2005
    The Cold North
    Thanks
    Bo
    couple options. Buy new Coilpacks and pop 'em in. Or find someone local that is willing to let you swap around some coilpaks to see if it helps.
    2020 Chevy AEV ZR2
    Feb 17 2008
    Thanks
    Bo
    Have autozone scan the codes for free.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    its one or more of your coilpacks!! definatly, i have been there and had thiat problem!!
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    May 24 2007
    Southern California
    i had the exact same thing happen to me last week. the coilpacks were going out, but not fully blown yet. swapped them all. All better.
    Kyle
    2.0L Revo GTRS Eliminator
    Feb 06 2008
    a good way to check for a bad coil pack is to unplug corresponding coilpacks and injectors, start with cyl 1 and move up to 4, and eventually by making each cylinder completely dead you will find the bad coilpack because it will seem like its running better when one set of coilpack/injector is unplugged.... you are getting the stutter vibration because your getting fuel and no spark.. so if you eliminate the fuel to the cylinder with bad spark then it will smooth out the operation a little.. atleast enough for you to know which coilpack is bad.
    snailspeed.net
    Saint Cloud, Fl
    highway fun = dead coilpacks
    instagram ------------> low_enforcement
    Feb 23 2008
    ko
    If a coilpack goes Wrong, would'nt it shutter when I rev the car at IDLE ? Caus if you read my first post, the car revs fine at idle...
    Bo
    Feb 06 2008
    you would think so, but you will really only see the stutter under load
    snailspeed.net
