Results 1 to 10 of 10
    Registered Member Two Rings maksim.7's Avatar
    Mar 15 2008
    NC
    debadged trunks:
    hey guys i have an a4, and i have an s4 badge on the trunk. previous owner did that, pretty pathetic. so i got the badges off, and i still have adhesive material on the trunk: what can i use to remove it without messing up the paint?
    -m.K
    1999 A4.
    lllllllllllllllllllllllllllllllllllll
    UKRAINIAN PRIDE!!!
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: debadged trunks:
    Been talked about before but along time ago. Heat, goo gone, elbow grease=safe way. If you still have the silhouette of the badge showing after that you may need to get some like 2000 grit sand paper like I did and then remove it with that and then polish and wax it back up to a shine. Its safe just not as safe as the first method.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Mar 27 2008
    2008 A4 Avant SE 2.0T 6MT
    Connecticut
    3M adhesive remover is best.
    WD40 will work and I have never had it damage my paint but I'm still skeptical of what it does to paint.
    Mar 15 2008
    NC
    oh ok thanks. haven't been on the forum for lung, so im a noob. ;)
    -m.K
    1999 A4.
    UKRAINIAN PRIDE!!!
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    x2 to goo gone, you may have to buff/polish it when youre through with that.
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    I wouldn't take sand paper to my paint, not even 2000 grit. 3M adhesive remover is good stuff and it should buff off with a good polish. You could also try acetone.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Mar 15 2008
    NC
    yeah i was thinking more of acetone.
    -m.K
    1999 A4.
    UKRAINIAN PRIDE!!!
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    heat gun, goo gone, a clay bar, then rubbing compund and wax. thats how i did mine....worked like a champ
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    heat + goo gone is the way to go. Worked for me like a champ
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    I have had better luck with WD40 than goo gone.
