Results 1 to 24 of 24
    Registered Member Two Rings whyb2nd's Avatar
    Feb 28 2008
    ALbq.NM
    How's Milltek catback sound in b6 ?
    not look'n to do down pipes at this time and wanting to know if catback has a good growl.
    07 997TT,meteor/blk,6spd,lsd,sport chrono.
    04 S4 sedan,silver/blk/bone suede,tip,Avarus AV4 19" wheels.
    08 Z06,blk on blk....
    Senior Member Two Rings kevintilokee's Avatar
    Oct 17 2006
    Westchester NY
    Re: How's Miltech catback sound in b6 ?
    sounds absolutely great. definately go non-res.
    Jan 21 2008
    2004 A4 1.8t Avant Sport
    Boulder, CO
    It has a more refined sound, fairly similar to stock when not under load. Under load it gives off a good growl. My friends refer to it as the subwoofer, especially engine braking below 2000rpm.
    Dec 05 2006
    So. Cal.
    It's a very refind euro sound which is similar to stock. Nice thing about this system is that it's 2.25" and not 2.5".
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    a lil searching on the forums will point you to youtube. and you can read all the threads beforehand.
    just by me looking at page 2 you can find your answers.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    what makes 2.25" better?
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Feb 28 2008
    ALbq.NM
    Quote Originally Posted by b00st View Post
    a lil searching on the forums will point you to youtube. and you can read all the threads beforehand.just by me looking at page 2 you can find your answers.
    sorry to bother you, next time why don't you just pass my thread....
    Thanks to you guys that gave your comments.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by channad View Post
    A 2.25" system will keep the exhaust gases hotter as they exit the car vs a 2.5" system. Hotter gases move more faster. It's about keeping the velocity of the gases up and to do this they should be kept as hot as possible.
    The more you move away from the stock pipe diameter, the more bottom end torque you lose. You can run a 2.5" system but I perfer a 2.25". In an Audiworld shootout, I think it was Frankstein's car, produced the most power, and he just had a Milltek cat-back, along with a few other mods.
    Seeing as the stock system is a 2" system, I like the idea of just going one step up to to a 2.25" system.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    I love mine.. Go non-res...
    Veteran Member Four Rings ItzDarrellS4's Avatar
    Jul 14 2007
    A Sedan, a Hatch, a SUV, and a Pickup
    The Live Free or Die
    go to youtube and enter miltek B6 S4, a bunch of clips come up
    mpg's lol
    Oct 14 2007
    Mammoth Lakes, Ca
    so if one were looking for a sound that's just a little bit louder than stock, would they go res or non res with the milltek CB?
    Established Member Two Rings Shonobi's Avatar
    Feb 24 2006
    2004 S4
    Dirty Jersey
    then go with non-res
    Veteran Member Three Rings tatarin's Avatar
    Feb 11 2008
    05 B6 S4 Nogaro 6spd
    deerfield IL
    it sounds great... with either res of non- i have the resinated and i love it. at crusing speed you cant really tell you have an upgraded exhaust, but when you step on it has a nice clean rumble.
    Mar 24 2008
    CA
    Re: How's Milltek catback sound in b6 ?
    I have resonated and they sound nice. It's not as noticable at lower RPMs but there is definitely a difference. Hit the gas and they sing!
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    I bought a non-res for my S4.
    When I first had it installed it sounded a little droney at around 2k rpm, but now that it's got a few kms on it it has mellowed a little and sounds fantastic.
    As others have said, if you're only going cat back get the non-res. If getting the full exhaust I'd personally go the resonated system instead.
    Feb 28 2008
    ALbq.NM
    nice feed back, thanks everyone.....
    Established Member Two Rings H0LLYW00D's Avatar
    Jan 05 2008
    Detroit
    resonated with downpipes = the sexor
    Veteran Member Four Rings PenguiN's Avatar
    Nov 12 2006
    RR Sport SC-B6S4-Gallardo
    DC
    a guy with a catback got better numbers than guys with DPs and cats?!
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by PenguiN View Post
    Read it and weep, or not! Frankenstein's car is the one!
    http://www.audiworld.com/news/05/b6dynoawe/
    Oct 14 2007
    Mammoth Lakes, Ca
    wow! Now that is eye opening!! Frankenstein had the biggest change in both numbers. 27.8 HP and 26.3 ft-lbs. Philip Yiu's car got better tq numbers but his hp suffered. Change of 12.1 HP and 35.9 ft-lbs.
    "This next car was dubbed Frankenstein and belongs to AudiWorld user JDBlueAudiS4. He runs an AWE chip, a Milltek cat back exhaust and a Stratmosphere Hyperflow intake."
    That's it, chip, CB exhaust and an intake. hmmmm...but if you really wanted power, you needed to buy a B5 S4...
    "To keep the B5 vs. B6 disscussion alive, at the end of the day we put the AWE B5 S4 Avant on the dyno. As you can see from the dyno chart below, it registered over 95 HP and 95 ft-lbs of torque more than the best B6 S4 of the day."
    Senior Member Three Rings Tek4ever's Avatar
    Mar 02 2008
    Silver 2004 S4
    Chicago
    Could it be the Stratmosphere Hyperflow intake helping or is that definitely a mod that doesn't help?
    Veteran Member Three Rings i_eat_staples's Avatar
    Aug 03 2004
    Wilsonville, OR
    its a german v8, either go non-res or dont do it at all =p
    '07 rs4
    '91 spec miata
    NW Quattro - NW Premier Audi Club
    Mar 24 2008
    CA
    I did DPs and resonated. It's plenty loud already - it would be too loud with non-res IMO. Then again, I need to keep it somewhat respectable for my job (consulting - occasionally drive clients around).
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    Pretty Darn Good
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
