Results 1 to 3 of 3
    Veteran Member Three Rings Blue04's Avatar
    May 28 2005
    2015 Q5 2.0T, past 2004 S4
    Long Island, NY
    Radio in safe mode, how to reset?
    I looked through the owners manual and i didnt see any instructions on how to enter the code. I have the code, i just cant figure out how to put it in. Apparently you need to hold a few buttons simultaneously, i found a write up on here but it says to hold the p. scan and rbds buttons but that doesnt work on the symphony II. Anyone know how to do this? Thanks in advance.
    2015 Q5 2.0T
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Re: Radio in safe mode, how to reset?
    You hold down AS and RDS keys simultaneously till "SAFE" is replaced with "1000" (release keys immediately after 1000 appears). Then use the four leftmost memory keys (along the bottom edge of the display) to change each digit. Then hold down AS and RDS again to get it to accept the code.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    May 28 2005
    Long Island, NY
    thanks, ill try it in the morning
    2015 Q5 2.0T
