Results 1 to 10 of 10
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    245/40/19-Anyone????
    Curious if anyone has run this tire size?? and what issues or info you might be able to offer. I know there are alot of variables, just curious if anyone has any first hand experience. +35 wheel BTW. Thx
    Jun 14 2005
    Anaheim, CA
    Re: 245/40/19-Anyone????
    What car are you trying to put this on?
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    I went to mount them on my B7 and the back fit but the front hit the control arm I need 235/35 up front, they are on 19x9.5 A 8 Rims
    KO
    EcoLuxuryDetail.com
    6-Speed, Neuspeed Chip, Heat Shield, 034 Intake, Euro Jet PCV, 3" Magnaflow, Test pipe, Sport Suspension, RS4 Sway, Snub mount, Apexi super ground, K&N, RS4 Pedals, Podi, Hawk HPS, Super Blue Fluid, Chrome Mirrors, Clear cornered, Laminx, Debadged, Ziza Led, Xexon Interior, Alcantara boot, Infinity 1000W 12", painted markers, VAG's 19" A8 12 Spoke, 10 & 15mm Spacers
    Sep 17 2007
    trying to put them on a B7 S4. 19X8.5 +35.
    Mar 27 2005
    The Cold North
    Quote Originally Posted by S-Fore View Post
    you can do a 245-35-19 which is 0.2-0.3" larger diameter (25.7")than stock. The 245-40-18 is TOO large. It has a diameter of 26.7" where as stock OEM is 25.4" (235-40-18). Some folks use the 245-40-19 on their allroads.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    245/35-19 needs to be XL to be used safely
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Doc@tirerack View Post
    Correct!
    -Charles@VMRWheels
    Established Member Two Rings grease's Avatar
    Sep 12 2010
    walla walla wa
    tire size
    hi im new to this form, i want to put some rs4 rep. rims on my 2005.5 s4 b7. is it possible to fit 245/40-19 or do i have to stick with 245/35-19 the rims are 19x8.5. and will offset of 38 work, i also plan to maybe lower the car in the future inch-inch and half
    Sep 12 2010
    walla walla wa
    oh and will ET 38 offset fit
    Oct 06 2006
    South Bend, IN
    Quote Originally Posted by grease View Post
    ET38 should be fine depending on the design of the wheel. WE've had issues with the 245/35-19 rubbing without a fenderlip roll or adding negative camber, so I'd exoect the taller tire would be more likely to have issues.
