Results 1 to 3 of 3
    Established Member Two Rings CactusBiturbo's Avatar
    Jun 18 2007
    Pa
    Wheel bolt length for OZ? Help ASAP
    Does anyone know the wheel bolt size/length I need to fit OZ superturismo GTs on the B5 S4? I picked up a set, but I'm two hours from my car. I need to try to get bolts ordered asap to get them on my car by Sunday, long story. I did some measurements using a stock bolt on both wheels, and I came up with the bolt sticking out 11mm longer with stock. Which would make me think I need a 39mm shank? Stock is 28. I'm just not sure if this is right, since I was testing with a ball seat lug into a cone seat wheel for the OZ. I'm pretty sure the OZ is cone seat, was hard to see in there. Can someone verify this too? Searching wasn't very helpful.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Wheel bolt length for OZ? Help ASAP
    We list the bolt needed (for current wheel) at 36mm useable length with a ball seat. Call me directly with needs.
    Jun 18 2007
    Pa
    Thanks, I actually just ended up ordering a set from you guys
