Results 1 to 9 of 9
    Established Member Two Rings max09163's Avatar
    Sep 18 2007
    B6 Audi A4 1.8TM
    Kansas City
    Question Icelink to Armrest?
    Hey sorry for another thread - Anyone know how to hide the icelink cable from the back of the head unit down the center console and to the armrest?
    thanks!
    [max]
    ---Looking for USP Lower Front--
    Also looking for top of B6 armrest center console (black)
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Re: Icelink to Armrest?
    I can't find my thread with my install. (i'll keep looking...)
    Basically the small pocket below the arm rest has a base plate that you pull out. that gives easy access to the console tunnel.
    1. While my head unit was out, I fed my ice link cable down through the console interior until it poked out the bottom of the console tunnel on the passenger side.
    2. Pull out all the slack.
    3. Feed the end of the cable up under the console tunnel at the pocket until you can grab it from the pocket opening.
    4. Tuck in any slack in the cable under the console tunnel.
    5. Route the cable into the arm rest through the access hole in the bottom.
    6. Drink a beer.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    May 22 2007
    oakland ca
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    hey cjonesgo - in this pic you have the bottom of that cubby piece off. how did you take it off? people have told me it doesn't come up?
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    May 22 2007
    oakland ca
    the cover is there, but not in the correct position, it's sort of resting at the side. this is what the access looks like, see all the holes?
    pulls straight up. no clips no fasteners, just good old gravity (and maybe some friction)
    i just struck the blade of my pocket knife at the edge and pried it up. pops right out and goes right back in.
    Sep 14 2006
    Mass
    Thanks! I'm doing the install right now. you didn't remove the arm rest to route the wire easier?
    -Max
    Sep 14 2006
    Mass
    guys where is the best place to ground the wire for the ice link? i have it hooked up to a screw on the back of the radio but i'm not sure its the best place. i'll post a pic in a minute.
    -Max
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    I just followed the instructions here.
    May 22 2007
    oakland ca
    i didn't route up into the arm rest. I left mine in the cubby beneath on a bracket I made.
