Results 1 to 7 of 7
    Dec 20 2005
    02 Audi A4 1.8tqa
    Stoney Creek, Ontario
    going from stock to sport suspension
    Hey,
    Just wanted to know exactly what I need to go from non-sport suspension to sport suspension. Is it enough to just get springs/shocks/bumpstops or do I need more parts...like control arms, etc?
    Thanks
    Mike
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: going from stock to sport suspension
    I think springs, shocks, and bump stops is all you need.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    Dec 20 2005
    02 Audi A4 1.8tqa
    thanks sambrody44...can anyone confirm this for sure?
    Feb 09 2006
    Albany, NY
    I just replaced my stock 02 suspension with OEM sport springs from an 07 and Bilstein heavy duty shocks.
    So far so good (well- there wasn't as much as a difference as I had hoped for)
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    You might also go with an aftermarket kit. The Koni 'sport' suspension is apparently similar to the OEM sport - same amount of drop and ride stiffness, or so I'm told. That kit consists of shocks and springs.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i believe the koni has a lifetime warranty IIRC.
    if you dont want to pony up for new control arms, you may atleast want to replace the bushings.
    i have the stock sport sway bar available. pm me if you need it.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Mar 25 2008
    2004 A4 1.8TQ6M
    New England
    I believe there are different sway bars as well
