Results 1 to 40 of 58
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Ohhhhh haaaaaaaaarrrrrroo.....
    Veteran Member Three Rings fikes's Avatar
    Aug 04 2007
    2001 Audi S4 Sedan
    Perkasie, PA
    Re: Ohhhhh haaaaaaaaarrrrrroo.....
    Bitch. I want the funding you have.
    1997 Audi A4 Sedan 1.8t- Sold
    1999.5 Audi A4 Avant 1.8t- Sold
    2001 Audi S4 Sedan- Current
    Oct 29 2005
    10speed
    San Francisco, CA
    Yo Ian, hows the software comming? And what makes that Synapse shit so good?
    - Clint
    Sep 24 2005
    always in design
    Base map file is written. Should be up and running mid-week to next weekend Final tune late April.
    Synapse WG uses no diaphragm, has adj. pre-load. 6 boost settings and flow control.
    Synapse BOV is fast acting uses a piston (multi-tiered) that selfsenters un psi. won't leak boost and eliminates compressor surge and flutter dumping.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    Yowza
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    sexy.
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Feb 15 2007
    marimont
    Looks good. I just ordered a Synapse BOV after reading about them. I used a hks prior. I'll have to read up on that gate. Might switch to that also. I like diaphramless.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The Synapse stuff is top notch. Their FPR also looks great.
    Nice job Ian. It is coming along very nicely.
    Jim
    I Do Werk.
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    That looks really sick. Are you plumbing the wastegate back into the exhaust or a completely divorced dump?
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Looks good, does the turbo have a oil only cooled center section?
    Jan 25 2006
    A4 2.0T
    MD
    ^ Yes.
    Veteran Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    pardon my ignorance, I dunno shit about BTs
    Whats that in the 2nd picture
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by audiFUEGO View Post
    the manifold and open wastegate with dump tube
    - Clint
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    ^ wastegate
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Jul 07 2004
    socal
    Quote Originally Posted by Don Supreme View Post
    ^ Yes.
    Just odd that he would pick a turbo that for road racing.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    very nice. I am definately gonna need to do this within a year if the funds allow. BTW, how much does it cost to get a downpipe made to match the new turbo? I know fullrace has a dp to match their manifold....but those together is over $1500.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Oct 29 2005
    10speed
    San Francisco, CA
    why? it should have more top end with a spool like a 28rs
    - Clint
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    Mike means because its only oil cooled. Most road racers that use forced induction use oil and water cooled turbos.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Mar 09 2004
    nw michigan.
    Click on the top pic and scroll down for some more info on the two main types of turbo center sections.
    Jim
    I Do Werk.
    In Limbo Two Rings
    Feb 29 2008
    2000 audi a4 1.8t quattro
    durham, nc
    had never seen a graph like those before..interesting
    Jan 25 2006
    A4 2.0T
    MD
    careful...................
    Jul 07 2004
    socal
    If it has a spool of a 28rs then its going to produce a power level like a 28rs, this is how turbos work.
    Quicker spool = sooner peak hp.
    Smaller a/r = sooner spool but also has a lower flow rate and this is what limits peak hp. If you search about a/r you will find that when you increase the exhaust housing a/r you also get a increase of peak hp.
    The last person to try running a very small exhaust a/r GT30 on a A4 1.8t couldn't even hit 300whp.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    ^^^how small of an a/r was he using?
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    In Limbo Two Rings
    Feb 29 2008
    durham, nc
    id bet .62 t25
    Jul 07 2004
    socal
    Quote Originally Posted by pipe7284 View Post
    .55 a/r
    Part listed on their site
    210100-3
    4 bolt T3
    .55 a/r
    more on the turbo
    Sep 14 2006
    Lansing, MI
    ^^^^^was that just a waste of turbo?!?!?!?!
    SOLD
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    looks titsup!
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    King Kong Ding Dong
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Sep 24 2005
    always in design
    Indeed and I'll see what happens. I can always switch back to a Water Cooler turbo if problems arise down the line.
    I never just shut the car off and am one of those people who drives to cool down for 15 minutes or more.
    Feb 27 2005
    North Wales, PA
    i fart in my turbo to cool mine down faster
    Sep 24 2005
    always in design
    I don't need late hp or peak hp. I need it early and when exiting the apex and not at 7k rpms in 4th gear.
    This will spool up very early, not as early as the 2860rs but pretty damn close in comparison.
    We will all just have to wait till mid April to see just what she's capable of. I will have a plethora of logged data by then.
    Jan 25 2006
    A4 2.0T
    MD
    When are we getting a dyno out of you Poopie?
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    oh haro!
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    do you even know what a plethora is?
    lol sorry you dont have to answer that, i was kidding. i just had to quote that movie
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    haha thats what thats from!! I was thinking frantically trying to remember
    Feb 27 2005
    North Wales, PA
    Dyno...hhmmm...i dunno...maybe next weekend if i'm bored. Anyone wanna do some runs with me? Its $85
    Senior Member Three Rings Dietbudda's Avatar
    Sep 19 2006
    1998 A4 1.8t BT
    Perkasie Pa
    Poops, you going to pdw for your run? If so i'll head down, won't run, but i'll head down and see what ya do.
    B.A.T. coming soon...plus...
    Sep 24 2005
    always in design
    Quote Originally Posted by Dietbudda View Post
    2nd I'll come along and would love to Dyno there again after the final tune just to see variance in dynos etc..
    Feb 15 2007
    marimont
    So bassed. After my Synapse bov came in I noticed how stressed it was to have a straight shot of a vac line from the manifold. How are you going to route yours? Also did you find a filter for the bov that is highly recommened? If so where?
    Sep 24 2005
    always in design
    **Edit just looked:
    K&N and it's pretty much straight forward, from what I read.
