Results 1 to 40 of 55
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Homebrew digital boost/vacuum gauge sneak peek
    I miraculously ended up with some free time this evening, and finally got around to starting my boost gauge project. The display is the exact same size as the opening for the change/card tray so that is where it's going. I don't have the sensor in my hands yet, so I have a potentiometer filling in for it (ADC is the same as the +/- 30psi sensor I plan on using).
    Here it is with a neutral signal (equal to atmospheric pressure):
    Here is a shot reading 15psi after a peak of 22psi, and a peak of -8psi vacuum:
    Reading -4psi vacuum after a peak of -9psi vac:
    And as an added bonus, it's going to disable that pesky ESP every time I turn the car on :) :
    Future versions might include meth/water injection management, and boost control. But for now, its just a boost/vacuum gauge that automatically disables ESP.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Saint Cloud, Fl
    Re: Homebrew digital boost/vacuum gauge sneak peek
    okay when they are mass produced, I have to be the first get one
    instagram ------------> low_enforcement
    Oct 01 2007
    Too small
    N/A
    If there is enough interest I could maybe see doing a limited run of them, but realistically it would be more expensive than some of the commercial offerings out there.
    I'm also not sure how well it's going to fit behind the dash. The display portion itself is the ideal size for that opening, but the controller board attached to it is a bit larger, and I don't know what the back of that trim piece looks like yet. I might have to Dremel it to get the display in a good position.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Deactivated Four Rings
    Nov 19 2006
    MMM
    damn I had a long reply but lost it. Look up the inkjet method for PCB printing. What kind of uC are you using? I'm an AVR guy myself.
    Oct 01 2007
    Too small
    N/A
    Mega8, and I usually use perfboard for prototyping/one-offs, but I do have a laser printer here and the materials to etch. That wont help with the size of the controller board mounted to the display though, it comes attached, and uses those obnoxious conductive rubber strips to tie the glass to the board, with it held down by that black frame. No chance of splitting them up.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    great, now make it to where it installs in the card holder slot so that it flows and looks OEM and ill be wanting it for sure :)
    Feb 17 2005
    Sarasota, FL
    And how the hell did you know how to make that work?!?!
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    I have been wondering why one couldn't be hooked up to the radio feed, seems like a perfect place to have the display. If the radio can feed CD and track to the dash display then it seems this would be quite doable, just need to figure out the interface.
    Nice work BTW.
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    I got a secret for you... boost can be displayed in your AC controls...
    shhh
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Feb 19 2008
    Blackhawk, CA
    Quote Originally Posted by martini View Post
    shhh
    Care to share a little more about this?
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    I did a custom digital boost/vacuum gauge in the lower corner of my rearview mirror but the electronic boost sender has since failed. Was really nice when it was working. Where are you picking up your readings from? CAN BUS??
    Quote Originally Posted by nihil View Post
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    Quote Originally Posted by RLB6 View Post
    hes going to put in a pressure sensor it sounds like... there is already a boost sensor which transmits on CAN which is probably easier to use
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    ^ shhh? explain haha please
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Nice idea. I wish I knew more about electronics to tackle something like this myself. My mind works better with gears. EE classes were difficult but I figured out the basics.
    Even better is if you can pull all that data off the CAN Bus so you don't have to rely on additional sensors. It can be done. I know someone developing a device that can read anything off the CAN you want and display it on a digital read-out. I might be one of the first to receive such a device from said individual.
    -Doug
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    That is a nice setup you have made there.
    Oct 01 2007
    Too small
    N/A
    Thanks all for the kind words, that'll teach me to start a thread then go take a nap.
    Quote Originally Posted by NiveK1970
    It's just a one-off homebrew project for the moment, so don't expect to see them on your favorite tuners website anytime soon. A buddy asked me this morning about the possibility of a kit, or just a pre-burned microcontroller and parts list type deal, which would be a lot more likely.
    Quote Originally Posted by A4ringedONE8T
    Insomnia gives you more time for hobbies ;)
    Quote Originally Posted by sailor
    Actually another red display will be filling up the cup holder slot eventually. It will display ID3 information from the currently playing track on the embedded Linux machine that will be stuffed in the glovebox. I picked up a car2pc interface that lets you interface a carPC as a cd changer. It will also have a small touchscreen display that will be folded away most of the time (unless I'm mapping things or datalogging via vagcom), but the LCD will be the primary interface.
    I'm listening :)
    I'll be using an industrial grade amplified differential pressure transducer at +/- 30psi. It's temperature compensated from 0 to 50°C (32 to 122°F) with an acceptable drift outside those extremes. I'm not locked into this sensor though, so if anyone has recommendations on a good automotive pressure transducer I'm all ears.
    I wanted to stick with a standalone unit instead of tying it into the bus so I could use the same design on other vehicles. Also, my `02 does not have CAN, it speaks KWP2000/ISO9141, and if I want to measure via that bus, the carPC with vagcom will do well.
    dougy/martini: no CAN do :(
    winston: thanks :)
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Oct 01 2007
    Too small
    N/A
    Finally got around to picking up a sensor today, if I can find some time this weekend, I'm going to finish up the programming (convert vac to inHg, add a button to clear last peak, and another button to switch between mbar and psi/inHg), and weather permitting, get it installed in the car.
    Last month I picked up some parts to start a project similar to this. I found what looks to be a pretty reliable means of speaking most popular OBD protocols, and want to build a small digital dashboard/scope type thing. As much as I end up working on other peoples cars, it'll be a neat diagnostic tool to have around. It could also easily be adapted for an in-car display.
    You sure are good at keeping secrets... Not even a hint?
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Dec 06 2007
    Bump For An Awesome Homebrew Project!
    -Kirk
    BetaAlphaTau Member #58
    Aug 26 2005
    The '02 has CAN, Powertrain, Infotainment and Comfort/Convienience CAN busses. But is not CAN OBDII diagnostics capable.
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by AudiA4Turbo22 View Post
    Interesting, all the info I had seen pointed to them not speaking CAN at all until later. Do you know what revision?
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Three Rings converted2audi's Avatar
    Jan 21 2007
    B6 1.8T Quattro
    MI
    cant wait to see what that will look like when its actually installed......great work, wish i knew how to do stuff like that....
    She said its just a car...i said you're just a girl.
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    Bump because this is an awesome project and martini has everyone reading...
    Established Member Two Rings JohnnyG's Avatar
    May 03 2008
    too many....my audi: a4 b8.5 project
    LongIsland, NY
    shhh
    Hey, I've seen b5 s4's w/boost displayed in the the cluster DIS (I'd love to do that) but in the a/c control head? you gotta share.......
    Senior Member Three Rings dirtyserby's Avatar
    Jan 28 2007
    Bay Area, Norcal
    i wanted to do this myself, this is the pressure xducer i researched and planned on using.
    MPX4250A
    http://www.freescale.com/files/senso...t/MPX4250A.pdf
    i think its something like 20-30$
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by dirtyserby View Post
    MPX4250A
    Well, that's a head start on where I'm at with the OEM T-MAP (pressure+temp) sensor package. I can't find a proper datasheet, but did find a non-orientation-specific pinout, so I'll have to wait until the rain lets up to go test the harness for ground pin position (Jeep is hogging the garage).
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Jan 28 2007
    Bay Area, Norcal
    good luck
    very interested to see how this turns out!
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    That is totally rad! If you could let me know how to do that for water/meth management that would be amazing.
    the homebrew'd s4
    Dec 06 2007
    i say once u figure it out u should patent it!
    -Kirk
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by Overboostin View Post
    Yes indeed that would be amazing. I still have a bit to learn about meth injection before I start coding for it.
    I picked up a dual nozzle meth kit not too long ago, just haven't had time to install it. After I get that and the FMIC installed, and put a few miles on it, I'll have a better idea of what kind of programming it needs.
    I'm not doing anything even remotely patentable. All of this has been done before, I'm just doing it the hard way
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Aug 26 2005
    You can get some insight regarding IC water spray controller logic and water injection control logic here:http://www.autospeed.com/cms/A_110368/article.html
    Oct 01 2007
    Too small
    N/A
    Great reading there. Thanks for the link! There are some other pretty good articles there too.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    BUMP for a sweet ass project !
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Oct 29 2005
    10speed
    San Francisco, CA
    rediculous... Id love to have that
    - Clint
    Oct 01 2007
    Too small
    N/A
    Got a little more work done. The sensor is a 4 pin T-MAP type, which is a MAP and IAT effectively combined into one package. The odd part is, when I had the harness in the car apart to get the proper pinout, the thermostat feature is not used at all, only three of the wires are connected +5V, Ground, and signal from the pressure transducer. Adding IAT display to the gauge would be fun, but I have absolutely no idea what the temperature range is on this thing. Anyone out there have an idea?
    I thought it was a bit strange that they would choose a more expensive sensor, only to use half of it, and then require a dedicated IAT sensor attached to the manifold, adding even more cost. Maybe it's just a quirk on the `02?
    Sorry for the crap quality phone pics, battery on the digicam is dead. First up is the new startup screen (right before it disables ESP):
    And the new display showing boost in psi with peak holding, vac in inHg with peak holding, and on the right in millibar:
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Holy goodness.. that is amazing work!!!
    Oct 01 2007
    Too small
    N/A
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Oct 01 2007
    Too small
    N/A
    Anybody know how to get that stupid card drawer out?
    I've got the radio out, and it looks like it's going to be a bitch getting the LCD in that spot, but I won't know for sure until I can get the damn drawer out. I'd like to make it a reversible mod, but I think its going to require the mighty Dremel.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Oct 01 2007
    Too small
    N/A
    Got a good part of the dash/console off, but still couldn't get the housing for the card drawer out. I did manage to rip the drawer itself out, breaking it in the process, and getting this particular display in there will definitely require some Dremel time. I buttoned it back up for now, if anyone has instructions for getting that drawer housing out it would make things a lot easier. Else I might try and attack it while its in the car tomorrow.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    May 03 2008
    LongIsland, NY
    pop off the upper console trim (above the card drawer and cup holder and below your decorative dash trim:carbon, metal,wood..whatever u have) the best way to get it out is with a plastic trim tool or carefully w a flat head screwdriver and a rag. pry it from the sides a little at a time and it will pop out. Then you will be able to access the area above the card holder. There are tabs on the housing which you will have to push down (a pic works well) you may have to push 'em down while pulling the housing.
    Oct 01 2007
    Too small
    N/A
    Thanks! I was going from the bottom up.
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
