Results 1 to 8 of 8
    Veteran Member Four Rings chunkyckn's Avatar
    Bay Area
    Pulstar plugs, have you tried it?
    Anyone here tried these?
    http://www.pulstarplug.com/index.html
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Re: Pulstar plugs, have you tried it?
    never heard of it till now would be interesting to see if anyone here has it and what differences are there
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Unless someone can show that these provide a great difference in performance there is no way Im paying this much for plugs. Read link
    https://www.pulstarplug.com/howtobuy...engine=1423370
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Dec 06 2007
    ^^there was a thread about this earlier!
    -Kirk
    BetaAlphaTau Member #58
    Senior Member Two Rings sailor's Avatar
    Feb 19 2008
    TBird.TC Miata A4Avant BMW.R80
    Blackhawk, CA
    This from Sparkplugs.com
    Can I use pulse plugs in an altered or modified engine?
    No. Pulstar model recommendations are for stock, unmodified engines. If you have added an aftermarket turbocharger, supercharger, nitrous or any other product that increases displacement or compression to your engine you will require a colder heat range in order to avoid possible damage to your engine. Pulstar plugs only come in one heat range which will not likely be cold enough depending on what modifications you have installed. See the FAQ "I have slightly modified my motor, do I need a colder spark plug?" to help find the correct spark plug for your vehicle.
    2003 A4 B6 Avant 1.8T Quattro Sport Tiptronic REVO
    Mar 12 2006
    Costa Mesa
    Well that solves this issue. At least for me.
    I'll keep my money,
    Dec 28 2006
    Colorado
    They work great in my A62.7. see other posts I have made
    bestplugs promo code gets a 10% discount. makes it a little easier to afford.
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    oops cannot use them 2.0 and go
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
