Results 1 to 15 of 15
    Senior Member Three Rings oakenfolde's Avatar
    Jul 24 2007
    Las Vegas
    thinking about spacing and lowering the car...
    Alright so I was thinking about spacing my wheels like 5-8mm and lowering the car about 1.5" max.
    I looked at H&R for both... I have an 07 b7 s-line.
    I have 19x8.5 +38(maybe 35 I can't remember) offset rims if that helps with which spacers to get.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Re: thinking about spacing and lowering the car...
    If you can, go 8mm as a minimum so you can get spacers with a hubcentric ring. H&R springs will get you that drop...maybe more.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Mar 11 2008
    07' A4 S-Line ti avant
    Toronto Canada
    I like the idea you have but don't do the spacers. too much stress on the bearings, keep it stock. looks good that way.IMO
    Mar 11 2008
    Toronto Canada
    But do the coil overs and not just the lowering springs.
    Jul 24 2007
    Las Vegas
    so NO on the spacers?
    is anyone having problems with those? dont they come with extrended lugs and whatnot so everything is cool?
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    H & R might give you more than a 1.5" drop.. if you want 1.5" max you might want to consider coilovers or Eibach springs. Eibach advertises that it drops approximately 1.2" but sometimes it drops a little more.
    Veteran Member Three Rings AlexK's Avatar
    Sep 11 2007
    San Mateo, CA
    Quote Originally Posted by oakenfolde View Post
    I have 8MM H&R spacers on my rear wheels and have no problems. I haven't heard any complaints from anybody else either. Yes, you need extended lugs. I got mine second hand so i'm not sure if htey are included.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    how much extra stress is added on to the wheel bearings with spacers? replacing bearings is pretty damn expensive, especially when it involves more than one wheel...
    anyone know how much the life of a bearing is reduced?
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Jan 10 2007
    VA
    Running spacers is fine. Don't let people scare you about them. When you install hubcentric spacers with appropriately longer bolts...it is safe, there are no vibrations, and you aren't really putting much more stress on the wheel bearings.
    Many times people bust out a Geometry lesson and attempt to prove how 'bad' it is for your bearings. The math may be true, but there is no way to prove if that correlates to a noticeable decrease in bearing life.
    Many guys run spacers on OEM and aftermarket wheels and have been doing so for a long time without issue.
    Jun 02 2007
    2004 cbr600 rr 1988 16V scirocco
    vancouver
    I'm thinking about doing the same. I was wondering about the wheel bearings too.
    Veteran Member Four Rings Phrost's Avatar
    Jan 24 2007
    1977 VW Type 2 Westfalia
    Wisconsin
    Running spacers will not add any significant amount of stress to your vehicle. You will not feel a difference when you drive, and no parts should wear prematurely. Don't worry about it at all.
    and spacers usually do not come with extended lug bolts. I've seen companies put together packages on occasions, but not often. Make sure you buy good spacers, like H&R's
    Ignorance is bliss.
    Jun 02 2007
    vancouver
    thanks Phrost!
    Jan 24 2007
    Wisconsin
    I see a bunch of people saying that wheel bearings might prematurely wear if you run spacers, but seriously... all they do is push your wheels out maybe 10mm.
    In threads where people are asking about wheel sizes, do you see people saying "get a et40 offset, if you buy et30 your wheel bearings will be overly stressed!"? No, because having the wheels sit only a tiny bit further out is very minimal.
    Ignorance is bliss.
    Mar 11 2008
    Toronto Canada
    Quote Originally Posted by AlexK View Post
    Anything 10mm and thicker bolts are included.
    Jan 24 2007
    Wisconsin
    I've never seen that... Where are you finding H&R spacers that include extended lug bolts for anything 10mm and up?
    Ignorance is bliss.
