Results 1 to 15 of 15
    Dec 09 2005
    Sayaovong
    Rear Lower Control Arm Bolt
    Doing the rear wheel bearing and using Mark P's write up. I am stuck trying to get the rear lower control arm bolt off. The bolt just spins with the nut. I've searched and found nothing about how to not make the bolt spin with the nut. Is there a trick that you need to know to get this bolt off? TIA.
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    May 06 2004
    W124s
    PA
    Re: Rear Lower Control Arm Bolt
    Use a wrench to hold the bolt, one to remove the nut.... Am I missing something here?
    Keep right pass left, it's the law!!
    Dec 09 2005
    Sayaovong
    There is no where for a wrench to hold the bolt. It is the rear lower control arm, not the front rear lower control arm.
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    Senior Member Two Rings S_four's Avatar
    Dec 12 2005
    2013 Sierra, 08 Grizzly
    I was in the exact same position. Couldn't figure it out either. Got fed up and brought it to a shop. Sorry for the useless post. :-)
    01.5 S4
    3L GT || R8 Reps || Vogtland Coilovers || Some other stuff too
    May 06 2004
    W124s
    PA
    Ohhhhhh..... you mean the rear tie rod nut then... there are two control arms in the rear, upper and lower. Then the "tie rod" that goes inbetween the parking brake cable and the brake line, is this what you mean? Air tools are your friend here. A simple blast with an impact makes it come off easily most of the time, then an air hammer to shock it free from the bearing housing. Since its loose, you may be able to use a hammer to push the joint into the knuckle to get a turn -or- use some large channel lock pliers or the like to keep pressure on the joint so it doesn't turn in the knuckle. try that
    Dec 09 2005
    Sayaovong
    I'll give it a try. TIA..
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    Feb 17 2004
    Sterling, VA
    I just want to make sure we're discussing the right part here.
    Is this regarding the front suspension's lower rearward control arm?
    OR
    Is it regarding the rear suspension's lower control arm attachment point?
    If this is about the front lower rear control arm, you will need an allen key to counterhold the balljoint stud and then use a box wrench or openend to turn the nut. Otherwise, the balljoint will spin in it's socket as you try to loosen the nut.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Dec 09 2005
    Sayaovong
    This is the rear suspension's lower control arm attachment point. On the back side of the bolt, there is nowhere to clamp anything. Do you have any other ideas or trick to use to try to get this nut off?
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    Feb 17 2004
    Sterling, VA
    I've done that job before and I don't remember there being no head on the bolt.
    Here's the steps right from the Bentley Manual:
    So essentially, unbolt the strut from the control arm, unbolt the arm from the wheel bearing housing and then unbolt the arm from the subframe (X2).
    Which of these 3 spots is the place you're having issues with?
    Brett - Moderator
    Issue?: email me.
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    i <3 daft, hes so helpful.
    Dec 09 2005
    Sayaovong
    It's not pictured in those pictures. It is the bolt that holds the upright to the lower control arm. You can see the connection in the first picture where it runs between the brake lines. And in that picture, there is no head bolt as well.
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    Feb 17 2004
    Sterling, VA
    If you're referring to the bolt labeled #2 in the disassembly steps, that is the bolt labeled #6 in the exploded view.
    Brett - Moderator
    Issue?: email me.
    Dec 09 2005
    Sayaovong
    Yes, I think that is the bolt. There is no head on the bolt. So when turn the nut, the whole bolt turns with it. Is there a trick to hold the bolt in place so I can turn the nut off?
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
    May 06 2004
    W124s
    PA
    He's gotta be talking about the tie rod.... look straight above #2, where the arrow points. Try what I said above and if that doesn't work, well you suck lol. You may need a buddy to squeeze the crap out of the joint with your huge channel locks, or maybe even a C clamp might work? If you had air tools, it wouldn't be a prob. If you can tighten it, you might try tightening the crap out of it, spray with some silicone, then loosen......
    Dec 09 2005
    Sayaovong
    Thanks guys for all the suggestions. I finally gave up and took out the lower control arm from the back. Was able to get the nut tighten back on. Thanks again.
    2003 RS6 Ebony
    2010 Q5
    2014 Q7 S-Line
