Results 1 to 11 of 11
    Veteran Member Three Rings audipcanugo's Avatar
    Oct 19 2005
    2009 Audi A4 Premium - Sport package
    Baton Rouge, LA
    codes P0171 and P0507....
    Need some help here. I know what the codes mean but I cant locate the problem. No split hoses, etc...When I put it in park the RPMs are low (sputtering almost). Driving I get hesitation. Any ideas?
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: codes P0171 and P0507....
    Quote Originally Posted by audipcanugo View Post
    Bad Maf?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    171 sounds like a bad MAF, I'll have to check on the 507
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I got p5070 after reving it for a while at IDLE.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Oct 19 2005
    Baton Rouge, LA
    Bad MAF is one of the possibilities how do I check that?
    Oct 19 2005
    Baton Rouge, LA
    507 just means idle is too low. Car is running lean. In park my car just sputters and acts like its about to die.
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    could be running lean cuz of bad maf
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    I got a 171 code and it was a leak in one of the vaccum hoses on the intake, not the maf.
    GO KNIGHTS!
    Oct 19 2005
    Baton Rouge, LA
    Well I can't find a leak....maybe I'm not looking hard enough. How did you find it?
    Feb 21 2008
    Orlando, FL
    I didn't, a mechanic did, for about $105! It was toward the back in front the battery. I was in the bay when he was testing it and saw it leaking out. Part was $150-200 if I remember correctly.
    GO KNIGHTS!
    Oct 19 2005
    Baton Rouge, LA
    F that.
