Results 1 to 7 of 7
    Senior Member Three Rings Mad_Audi's Avatar
    Mar 06 2006
    97 Amulet Red Audi A4 1.8T
    Greenville, NC
    Question car hasnt been started in awhile
    i've got a friend that has an AEB passat. it hasnt been started in about 6 months because he was in Iraq. What should i tell him to do other than changing the oil? should he drain his gas tank? he told him maybe take the valve cover off and prime all the cam lobes just to lessen friction. i'll probably be helping him do this so any pointers would be appreciated.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    Re: car hasnt been started in awhile
    give me the engine
    Mar 06 2006
    Greenville, NC
    srsly....little help guys
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    was it parked indoors with heat? I would start off with an oil change and then adding sta-bil or something in the fuel. then soon after its running probably the the plugs. and possibly might need a trickle charger for the battery.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    ICM maybe
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Mar 06 2006
    Greenville, NC
    car was parked outside in North Carolina. I dont think it got below 20 degrees this year. so..oil change, plugs, ignition control module maybe (if it went bad). no need in taking the valve cover off oiling everything manually?
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    i would change the oil, put some fresh gas in it, and charge the battery. You might also want to check all the wires for damage from mice and shit, same with the air box, small animals like to make nests in there sometimes. But fter you get it started just drive it around for a while, and if there is a vibration from the wheels than its most likely from sitting in one spot for so long.
