Results 1 to 7 of 7
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    Size of Oettinger wheel lug bolts? Wheel Locks...
    Does anybody have wheel locks for their Oettinger wheels? What size is the bolt? is it a ball fitment?
    I need the length of the threads if anybody has a bolt handy so I don't have to remove one of my own...
    If you know this, Thanks very much.
    BTW: They are not the same size as stock...
    2004 A4
    Central Jersey
    Re: Size of Oettinger wheel lug bolts? Wheel Locks...
    Bump
    2004 A4
    Central Jersey
    Bump II
    Veteran Member Three Rings quattrotman's Avatar
    Sep 26 2006
    I used these...Oettys use a ball seat.
    http://cgi.ebay.ca/LUG-BOLT-Wheel-Lo...742.m153.l1262
    2004 A4
    Central Jersey
    Do they fit? I definitely need a 39mm shank length? How long is the stock shank length?
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Man i found the answer on the forum when I bought my wheels, but now I can't remember and trying to find it again and it's not coming up...
    I know that your shank needs to be longer than stock and it's ball seat. I bought my RAD wheel locks on PureMS.com.
    2004 Audi A4 1.8T Quattro 6-speed
    • Bilstein PSS9 • APR Stage 1+ w/ TT225 Injectors • Forge 007
    • JHM SS • Oettinger RZ 19x8.5 • Podi • RS4 Rear Sway
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Found it...
    http://www.purems.com/products/product.php?II=698
    Quote Originally Posted by MikekiM View Post
    It's actually 34mm length.
    The key however is that the ball seat is R12. This is a VERY unique ball seat dimension on a 14mm bolt.
    Genuine Audi bolts for example are R13mm ball seat.
    Oettinger bolts are pretty unique, and quite expensive if you purchase them from an Oettinger dealer.
    As an alternative, you can purchase OZ Superleggera bolts, and trim them 2mm. Those are 36mm R12 ball seat. You'll get the correct ball seat (which is very important) and end up with the correct length.
