Results 1 to 9 of 9
Thread: MBC problems
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    MBC problems
    I installed a turboxs hpmbc and only got seven psi. pulled over tried to change it and it was about 5 psi. i thought i was running off the wastegate so i flipped it and got the same result. what gives??
    fyi i never boost anywhere near 14 psi.
    barrett
    2019 SQ5 Prestige
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Re: MBC problems
    Quote Originally Posted by texasboy21 View Post
    barrett
    Are you running a boost controller as opposed to getting a chip?
    Mar 11 2008
    B7RS4 & e46Ms
    Re: MBC problems
    the mbc should go between your wg and boost/vac line off the turbo. Some run it off the vac line at the intake but you'll get a slower response. Not sure if the factory controller needs to be connected still for monitoring/metering purposes, someone else will have to chime in on that one.
    On the HPmbc, it should have two adjustments, a high, and a low setting. Adjust the high setting first to get you near the boost you're looking for, then use the low to dial it in presicely (the high setting will adjust from wg spring pressure onward, the low setting can only adjust within a window of +/- 1-2 psi of the high setting)
    Apr 01 2007
    houston texas
    Re: MBC problems
    Can someone please clarify more about how to run it without the N75, which is in fact plugged into the TIP with the electrical connection. I origanally had the bottom nip connected to the brass colored ball shaped item which is what i believe is the wasgate. and the other line on the pressure, side nip. Got only 5psi, then switched the two and have the same result. I dont think i hit limp cause i never boosted over stock pressure. Any ideas?
    barrett
    2019 SQ5 Prestige
    Apr 01 2007
    houston texas
    Re: MBC problems
    Quote Originally Posted by audipotential View Post
    I am running a boost controller to up the boost a few psi, staying under 14. Apparently a mbc can give faster spool and hold boost a little longer and better than a N75 so i thought why not. It did solve a first gear surging issue do its not all bad.
    barrett
    2019 SQ5 Prestige
    Apr 01 2007
    houston texas
    Re: MBC problems
    ttt
    2019 SQ5 Prestige
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    Re: MBC problems
    barrett
    Are you still stock ecu?
    -Kris
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Re: MBC problems
    the car is not going to run on a MBC on a stock software though.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | JBOM 100 Cell downpipe | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Jun 29 2007
    Raleigh, NC
    Re: MBC problems
    sounds like you're in limp mode, probably from an overboost error.
    take off the MBC until you go BT
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
