Results 1 to 8 of 8
    Senior Member Two Rings giacb6usp's Avatar
    Sep 17 2006
    05 A4 1,8T
    Long Island. NY
    Installing TP gotta prepare...
    Since my PSI TP is on its way to my door, I need to prepare tools for installing process. From what I seen so far, I need tools for O2 sensors F/R, 3 bolts on turbo outlet, 2 connects testpipe to downpipe. Does anyone can tell me what those sizes are, and anything else I need such as extensions and such. Any info greatly appreciated.!!
    USP CLUB MEMBER #4
    K04 - Miltek Exhaust - PSI TP - Racetec FMIC - TT 225 - SB OFE SS - AWE Boost Gauge - AWE Tuning Pedals - Forge 007P- RNS E - Oettinger - Apexi TT - Fujita Filter - S4 F.Grille - ECS D.Mirror - Hawk HPS F/R - Hardwired V1 - Hitachi E CP - Bosch FR5DTC - H11 Höen Xenonmatch - APR Snub - VAG-COM License with HEX-USB+CAN Interface -
    Veteran Member Three Rings CrystalBlu1.8T's Avatar
    Sep 14 2006
    2017 RS3, 11 Q5 S-Line,
    Re: Installing TP gotta prepare...
    Prepare for sum scrapes from that cat its a pita.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Well from what I read, most people that did the TP install said their bolt were rusted on and they had to use a torch. I would do the TP install, but using a torch that close to the engine kinda scares me.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Sep 14 2006
    No need for the torch just get some PB blaster.
    Feb 17 2006
    PB Blaster is not always guaranteed.
    Feb 17 2005
    Sarasota, FL
    Shit sucks! Its a bitch to get to the bolts around the cat. Make sure you have some ratchet extensions, swivel head ratchet wrenches help, you'll also need an allen to take the 3 drive shaft cover bolts off, makes it alot easier to get in there
    Sep 14 2006
    Deff take the airbox out too.
    May 24 2007
    Southern California
    Quote Originally Posted by A4ringedONE8T View Post
    exactly. and pb blaster worked for me on one bolt.
    i also had a friend help me, which was a world of help.
    1 guy under, 1 guy above (<<kinda sounds gay), holding each side of the screw and bolt.
    i'm sure it would have been pretty hard doing it alone.
    Kyle
    2.0L Revo GTRS Eliminator
