Results 1 to 4 of 4
Thread: Tire question
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Tire question
    I recently bought some OZ Ultraleggeras (19x8" et35) and have 245/35/19 tires on them from Tire Rack. My car is lowered, not too much, but enough to cause rubbing. If I stiffen my suspension the rubbing only occurs on bigger bumps, but I'd like to daily drive on the softest suspension. Do you think changing to a 235/35/19 tire will eliminate the rubbing? I know some tires tend to be wider than others, I currently have Sumitomo HTR Z III tires if that helps at all.
    Veteran Member Three Rings A4 JooN 2.0T's Avatar
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Re: Tire question
    there was another post in b7 about the 245s rubbing so stick with e 235s i just got a set of ultras and going to put them on today but i got 18s with 235 GL
    sumis?? hmmm you should of invested a lil more i mean after all you did spend 1300 on rims alone i got me yoko s.drives =]
    2007 B7 A4 2.0t Qtip Brilliant Black on Black -=- Revo Stg 2/SPS2 -=- Milltek Catback Labree Quads -=- Eurocode Testpipe -=- K&N Filter -=- Forge DV -=-RS4 Rear Sway -=- ECS Quick Spool Pulley -=- Neuspeed SS -=- 20% 3M Tint -=- Lamin-X Yellow Fogs -=- LED UV Blacklight Interior Lights -=-O.Z Ultraleggera Black w/ Yokohama S.Drives
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Tire question
    235/35/19 can't carry enough load to be safe for use on the car, sorry. Front axle is rated to carry 2,756 lbs., and the 235/35/19 (XL) can carry 1,356 at best.
    Sep 24 2007
    |07 B7 A4 2.0t Qtip|
    nyc
    Re: Tire question
    Quote Originally Posted by Doc@tirerack View Post
    oh yeah i forgot to mention that i have 235/40/18 with the ultras as they are 18x8 =]
