Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Mar 20 2008
    Lexus GS 400, Mazda Protege5
    Michigan
    B7 A4 reliability - better info
    Because existing sources of auto reliability information left much to be desired, in late 2005 I started conducting my own reliability research at TrueDelta.com. TrueDelta reports absolute stats like "trips to the shop" that make the differences between cars much clearer. Results are updated four times a year, so any significant changes in a model's reliability become apparent quickly.
    About 125 B7 owners have signed up to participate, enabling us to provide results for a couple of model years. (So far, the B7 is holding up better than earlier generations.) But with more participants we could provide more precise and more detailed results.
    Participants simply report repairs the month after they occur on a one-page survey. When there are no repairs, they simply report an approximate odometer reading four times a year, at the end of each quarter.
    To encourage participation, panel members receive full access to the results for free.
    For the details, and to sign up to help out:
    Vehicle reliability research
    TrueDelta.com
    Vehicle reliability, fuel economy, and price comparison information
    Jun 02 2007
    2004 cbr600 rr 1988 16V scirocco
    vancouver
    Re: B7 A4 reliability - better info
    great idea!
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    I signed up.
    Mar 20 2008
    Michigan
    Thanks, I appreciate it.
    Additional participants always helpful.
    TrueDelta.com
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    I also signed up, thanks!
    Senior Member Two Rings intonation's Avatar
    Apr 09 2008
    Lawrence, KS
    I've been in for 3 months now. Great service.
    Mar 20 2008
    Michigan
    Quote Originally Posted by intonation View Post
    Thanks for the support, it helps.
    I've just released results for the 2006 and 2007 A4. For both years, the repair rate is better than the average, and better than the B6.
    Will this continue to be the case? Time will tell. With prompt quarterly updates, this survey will closely track these cars as they age.
    I'd like to also provide a result for the 2008, but especially need more participants for that year.
    For the full set of results, and sign up to help (if you haven't already):
    TrueDelta Vehicle Reliability Survey results
    TrueDelta.com
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    This is a great idea. After we take delivery of our B7 Avant, I'll sign up.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Mar 20 2008
    Michigan
    Thanks for the encouragement, it helps.
    What I usually suggest is to sign up with the current car, then let me know of the switch when it happens.
    TrueDelta.com
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    signed up
    Veteran Member Three Rings jahciple's Avatar
    Mar 10 2008
    08b78ea42t6mtnq
    Long Beach, CA
    that's awesome, i will sign up later because i have an 08.
    Driver: Dustin
    Projekt: Audisciple
    Gamertag: JAHciple
    May 21 2008
    AZ
    i'm in.
    Mar 20 2008
    Michigan
    Quote Originally Posted by jahciple View Post
    The research only collects data going forward, so if you wait to sign up you won't be able to report on as many months.
    People can't report what happened before they signed up on the main survey because this might distort the results.
    Next update in August. Additional participants would certainly help.
    TrueDelta.com
    Mar 20 2008
    Michigan
    If you've signed up to participate but haven't yet responded to the survey (via a link in the email you received), please do. And if you haven't signed up yet, I hope you'll consider doing so.
    TrueDelta.com
    Mar 20 2008
    Michigan
    Those results in a week or so.
    Looking forward to the next set, in November, can always use more participants. Especially for the 2008.
    TrueDelta.com
    Senior Member Three Rings fromGMCtoAUDI's Avatar
    Feb 03 2008
    '08 audi A4 2.0T
    alexandria, VA
    I have a 2008 & I've signed up but it won't let me report anything.
    Do I have to wait until you send the survey form to my email?
    Mar 20 2008
    Michigan
    Yes. The next email with links to the main survey will go out in about ten days. I check new entries for errors then activate them before sending each email. After that you'll be able to access the survey through the site as well as through the email.
    The other surveys, for fuel economy, repairs that happened more than a month ago, and so forth, currently use a separate vehicle list. You can add your car to that one and participate in those surveys right away, if you want.
    I'm in the process of merging the two lists and making the whole process clearer and simpler, but it's a lot of work, so it won't happen overnight.
    TrueDelta.com
    Mar 20 2008
    Michigan
    Updated results have been posted. The 2006 and 2007 appear to have repair rates near the average, perhaps a bit better than average.
    The reported repair rate for the 2008, with a marginal sample size, is better than average. With a larger sample size, it might be closer to the other years.
    For the full set of results, and to sign up to help out:
    TrueDelta.com
    Mar 14 2005
    stl mo
    interesting. I signed up.
    2003 Platinum Grey MKIV Jetta 1.8T Tip[sold]
    2002 Dolphin Grey B6 A4 1.8T 5spd Quattro[sold]
    2005.5 Quartz Grey B7 A4 2.0T 6spd Quattro[sold]
    2011 Brilliant Black 8p A3 S-Tronic Quattro
    Mar 20 2008
    Michigan
    Additional participants always helpful. We especially need more 2007s and 2008s.
    TrueDelta.com
    Mar 20 2008
    Michigan
    Updated results in a couple of weeks.
    560 A4 owners signed up so far. A great start, but more remain needed. (809 3-Series are signed up.)
    TrueDelta.com
    Mar 20 2008
    Michigan
    Those results, based on owner experiences through the end of September 2008, have been released.
    B7 A4 reliability, in terms of successful repair trips per 100 vehicles per year:
    2006: 82, about average
    2007: 55, average, maybe a bit better
    2008: 26, much better than average, but based on a small sample size
    Descriptions of all reported repairs have been posted to the site, for those interested in that level of detail.
    For the full set of results, and to sign up to help:
    TrueDelta.com
    Mar 20 2008
    Michigan
    This month's survey is the last before the February results. Well over 600 A4 owners signed up so far. A very good start, but more remain needed.
    Car reliability research
    TrueDelta.com
    Aug 26 2008
    toronto
    id do it but im all the wAY in canqda lol
    Aug 26 2008
    toronto
    lol i should read.
    i joined
    Mar 20 2008
    Michigan
    Thanks, I appreciate it. FWIW, hardly anyone reads anymore. Skimming is much more common.
    The latest Car Reliability Survey results were recently posted. The reported number of repair trips per 100 cars per year for the Audi B7 A4:
    2005.5-2006: 56, about average
    2007: 40, better than average
    2008: 34, better thana average
    So, quite good so far, and much better than many people expect from an Audi.
    A big thanks to everyone who has been helping. We'll have further updates in May, August, and November. Additional participants would certainly be helpful, especially if we start splitting results by engine.
    We now have a separate results page for each model. The one for the Audi A4:
    Audi A4 reliability comparisons
    TrueDelta.com
    Mar 20 2008
    Michigan
    Updated results next week. 812 A4s signed up so far. A great start, but more remain needed to properly cover all model years and powertrains.
    To help get yours included:
    TrueDelta.com
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by mkaresh View Post
    And the replies often confirm that.
    Tell me -- how does TrueDelta compare with Consumer Reports Reliability findings? They should be, on average, the same since both are based on consumer feedback.
    Mar 20 2008
    Michigan
    TrueDelta's stats tend to track with those in CR, but there are a few sources of variation.
    First, we ask about all repairs, not just those owners "considered serious." CR's wording opens the door wide for owner bias.
    Second, people respond to our survey within a few weeks of having the repair. CR's survey relies on people's ability to remember repairs that occurred up to a year ago.
    Third, our May results will be 11 months ahead of their current results. So when a model's reliability changes, this shows up in our stats well before it shows up in theirs.
    TrueDelta.com
    Mar 20 2008
    Michigan
    We've updated the results for the B7 A4 to include owner experiences through March 2009. In terms of successful repair trips per 100 cars per year:
    2008: 56
    2007: 43
    2005.5-2006: 65
    All three are average, which is better than many people expect from an Audi. The B6s have required more repairs.
    A big thank you to everyone who has been helping. We'll have further updates in August and November. With more participants, we could provide more precise information and post separate results for each engine.
    TrueDelta.com
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Im in.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Registered Member One Ring santo666's Avatar
    May 23 2009
    Norwich, CT
    plus one
    "-Those who say it can't be done, shouldn't interrupt those who are doing it-"
    Mar 20 2008
    Michigan
    Quote Originally Posted by santo666 View Post
    plus one
    Thanks, and love the sig.
    920 A4 owners now signed up--gaining on the 3-Series. Updated results next month.
    TrueDelta.com
    Mar 20 2008
    Michigan
    Updated results soon. The more owners participate, the better the information we can provide to everyone.
    TrueDelta.com
    Senior Member Three Rings A4_Eyez's Avatar
    Jul 30 2008
    B7 A4 2.0T S-Line TiT Pkg. PB
    Charlotte
    I will sign up once I get back stateside since I do not have the Vehicle Information or current odometer reading.
    Veteran Member Four Rings psiaddict85's Avatar
    Dec 16 2008
    Cleveland OH
    just signed up as well
    22 []S6 Glacier/Arras
    19 []S4 Quantum/Magma
    16 A6 3.0T S-Line/Glacier
    15 []SQ5 Audi Exclusive/Ibis/Magma RIP
    09 []S5 V8 6MT/Ibis/Magma
    06 A4 2.0TQ StgII+ DTM/Moro
    99.5 A4 1.8T StgIII Silver
    Mar 20 2008
    Michigan
    We've updated the results for the B7 A4 to include owner experiences through June 2009. In terms of successful repair trips per 100 cars per year:
    2008: 57
    2007: 45
    2005.5-
    2006: 78
    All are about average, and quite a bit better than the B6.
    Everyone who has been helping, thanks, I certainly appreciate it. We'll have further updates in November and February. The more owners participate, the better the information we can provide to everyone.
    TrueDelta.com
    Mar 20 2008
    Michigan
    We'll have updated results again next month. Great participation by B7 owners. That said, with sample sizes more is always better, so additional participants are always helpful.
    TrueDelta.com
    Aug 01 2009
    2007 A4 2.0T
    Minneapolis
    Was signed up with my B5, and signed up on my current B7. Great resource for B7 owners. Like the addition of the gas mileage section.
    Senior Member Three Rings JohnUSMC's Avatar
    Jan 13 2009
    07 B7 A4 2.0T Quattro
    Dallas, TX
    Can people that routinely perform their own repairs contribute/participate?
