Results 1 to 9 of 9
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Garrett Turbo question
    Are the turbos made by Garrett for specific engines or are just for general application. I have a friend who is thinking about selling his GT28r from his Nissan but didnt know if the fitment would be different.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Re: Garrett Turbo question
    you would have to get a manifold with a T25 flange, and perhaps do some custom fab work because the turbo will sit diff. Its not a bolt on.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    So are Garrett turbos made for specific applications or am I just looking new manifold and flange? I'm confused.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You need everything that would come in a gt28r kit.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 21 2007
    "Old Yella"
    san antonio tx
    So its not the turbo ,but the accessories that make it fit our engine. Right?
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    most garrett turbos come in a couple of standard applications (different flanges) depending on the turbo. to make them hook up to your cars you will need an exhaust manifold for sure (many wont fit in the stock location regardless....hence the ATP housings for garrett turbos) as well as some exhaust modification. garretts can for the most part be clocked to adjust outlet locations as well...to a certain degree.
    to answer your q, they are pretty standard across the board...
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by DenverNoob View Post
    Ahhh, that basically answered my question , his flange is different.
    Feb 17 2005
    Sarasota, FL
    His flange is different yes but your manifold can be changed to match the flange on the turbo he has
    Senior Member Two Rings apexslider's Avatar
    Jan 09 2008
    Oregon
    buy this....its a good place to start
    http://www.034motorsport.com/product...roducts_id=712
