Results 1 to 14 of 14
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    Arrow BT/BAT spark plugs
    for future reference, what spark plugs are you BT/BAT guys running and how are you liking them. I'll need to pick some up soon. Post your setup and your plugs!
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: BT/BAT spark plugs
    bosch F6-DTC plugs here.
    Feb 27 2005
    North Wales, PA
    F6 DTC's here as well. Great plugs for the price. It helped a lot with the high boost high rpm where it was breaking up a bit.
    97 A4 2.0TQM
    Rochester, NY
    I run the NGK BCPR6ES at 0.032 gap. They are like BKR6E's but don't have the V groove, just a plain spark plug. They are a little taller than the BKR6E's and might not fit under coil packs, but work fine for me since I'm using spark plug wires.
    Dec 05 2007
    Thread Jack (to add to my subscription. and yes, I did search): What spark plugs are good for chips? I am a stocker and am going to chip soon with Dalhback. Most people seem to go with the NGK BKR7E. But I wanted to go with Bosch ones and I came across a thread that recommends Bosch F6DTC. I want the Bosch ones because no need for gapping and they seem to be able to run for 25k before change. I found the Bosch F6DTC, but they seem not to be recommended for Audis, but are for MK2. The only Bosch ones I found are here. Can anyone tell me if any of these are ok to run with just a chip on a ko3s? I want my new plugs installed before I get the chip installed. If these are not ok, can you tell me which 'Bosch' ones to run with? Thanks!
    Jan 06 2007
    NH
    ^^ NGK BKR6E's, I cant remember the preferred gap off the top of my head
    Dec 05 2007
    Thanks. But you don't know about which Bosch ones I could use? Pre and post chip. The reason I want Bosch is so I do not have to gap.
    Jun 20 2007
    2012 JSW TDI
    Raleigh, NC
    Quote Originally Posted by Euro-Tuner View Post
    vwvortex 1.8t FAQ suggests:
    For Chiped Cars - .028" gap:
    NGK BKR7E
    Autolite 3922
    Denso Iridium IK22
    22 ft-lb
    i use bkr7eix
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    <---bkr7e .32
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    i run f6dtc on k04, gt2871, and my 2.0 16v mk2. wow all around! great plugs & stopped my misfires on my bt.
    Dec 05 2007
    Are the Bosch f6dtc ok to run on a ko3s with and without chip?
    Jan 06 2007
    NH
    Quote Originally Posted by pinky View Post
    NGK BKR7E
    Autolite 3922
    Denso Iridium IK22
    22 ft-lb
    i use bkr7eix
    in that case I mized up the 6's & 7's, the 6's are for KO4's then
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    No, bkr6e's are too hot. Stock plugs are a 6 heat range, which is hotter than a 7 heat range on the NGK plugs. So, once you go to a chip and beyond you really don't want to run anything hotter than a 7 heat range NGK plug (not sure what the numbers are on other brands that would compare to the 7's).
    "You know you have a bad idea when Ford guys are making fun of you."
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    f6 dtc's ftmfw
