Results 1 to 40 of 60
    Veteran Member Three Rings Audi Advocate's Avatar
    Mar 26 2005
    2012 B8 S4, 2012 A3 Wagon
    Any S4 owners using Nitrogen in the tires?
    Is it a gimmick or of value?
    Current #1 2012 S4 3.0T DSG Technik with Unitronic Stage 1+, Milltek res., KW V2 coilovers, StopTech BBK, Alu Kreuz, H&R Rear Sway, BBS CH-R's, Michelin PS4S, Disabled wink, De-badged, ZIZA LED's, 30% tint and fancy aluminum pedals - Current #2: Wife driven 2012 A3 2.0T Progresiv- stock
    Dec 30 2007
    Constantly changing.
    DC
    Re: Any S4 owners using Nitrogen in the tires?
    I'd suggest contacting 2modfast, if I'm not mistaken he was running nitrogen filled tires on his B6 S4.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    I have them. Whats the question? I mean, they are just supposed to not leak out as much, and they don't, i guess? =)
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    The tire pressure stays more consistent than air, cold tire to hot tire and wide variations in ambient temperature. My local Costco tire store uses nitrogen. I used it in my race car but don't see the real advantage in a street car. If it was as easy to find as air then fine, otherwise not worth the trouble IMO.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    I'm running roughly 78% nitrogen, 21% oxygen. It seems to be working well.
    Sep 23 2006
    Houston TX
    Quote Originally Posted by ieatfishburitos View Post
    that's amazing, me too
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    21% Oxygen(O2) or atmosphere?
    1% Leftover?
    Established Member Two Rings brianmfournier's Avatar
    Dec 15 2007
    2004 S4; 2004 Acura MDX
    Cromwell, CT
    Damn it! I thought I was the one with this idea! Back to the drawing board for me
    Established Member Two Rings corstiaanw's Avatar
    Nov 09 2006
    Plano, Tx
    I run nitrogen on my B7 S4 avant and it does keep the pressure more constant here in Texas where we had snow last week and it's 90 degrees today.
    Dec 20 2006
    CAN
    I am using approx 1% Argon and 0.0001% Krypton in addition
    to 78% nitrogen and 21% oxygen.
    It's superman proof.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Dec 30 2007
    DC
    For those that have nitrogen filled tires.......have you noticed any ride quality difference.....also where did you get them filled.....and how much?
    Dec 05 2006
    So. Cal.
    Got nitrogen in my MKV and no air pressure fluctuation. It rides the same as air.
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    i believe its just for those who have great temp changes because it will not change the size of the nitrogen molocules..
    Established Member Two Rings 1145climber's Avatar
    Jul 04 2007
    MA
    Nitrogen is a ridiculous gimmick and waste of money. If it's free, go for it... if it costs a dollar or more, dont bother.
    Sep 24 2007
    Chicago
    Quote Originally Posted by fitzS4 View Post
    Sorry man but molecules never change sizes (with the exception of isotopes but again, it is what it is and it never "changes" size). Temperature determines how "excited" molecules get so higher temps = more excited (read: faster moving) molecules which excert a higher pressure on whatever they run into. Nitrogen is not immune to this effect, that would be breaking the laws of chemistry and physics, which are the only laws that actually make sense to me anymore.
    I cannot for the life of me understand why nitrogen > air > fumes from the back of my ass. You fill a tire to a certain pressure with a gas, end of story.
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    I think the theory about less pressure fluctuations is correct, but not because of size. The O=O double bond is not as strong as the N=N triple bond, so as temp (kinetic energy) changes, the O is more affected than the N would be.
    Jul 02 2004
    FL
    Quote Originally Posted by Lugi20 View Post
    Ions can can in size with charge, not molecules or isotopes.
    Sep 24 2007
    Chicago
    Quote Originally Posted by B18b1ex View Post
    The strength of the bond still has nothing to do with how much pressure the gas exerts. Bond strength only relates to the molecules tendency to drop other atoms for more favorable atoms. Hydrogen (H) has only 1 valence electron in the first valence shell, which can hold 2 electrons. This is why hydrogen bonds so well with other atoms, like, Oxygen for example, which is missing 2 electrons from its outer most shell. This is why a very common molecule forms on our planet, you guessed it, H2O!
    Listen, I will flat out tell you all that the most basic principle of fluids throws this Nitrogen bullshit out of the window.
    ideal gas law: PV = nRT
    P = Pressure
    V = Volume
    n = # of moles of gas
    R = gas constant
    T = Temperature
    When you solve for the equations using the same gas, you will always cancel out nR, leaving you with PV=T.
    Temperature, pressure, and volume will be exactly correlated whether you use atmosphere, nitrogen, or the fumes from the back of my ass.
    It does not matter what gas you use with regards to pressure and temperature!!!
    Feb 20 2005
    S4 CABRIOLET,Porsche Cayenne, MB ML320E
    montreal
    My local shop charges 100$ to fill all 4 tires. It is useless if you have air in your tires, you would have to remove the current air and refill with nitrogen. To do that, you would need 2 valves. The only advantage of nitrogen is to prevent pressure losses in cold climate or sudden abrupt weather changes. I haven't noticed any performace gains or road feel variability.
    Established Member Two Rings cops04s4's Avatar
    Jul 06 2007
    04 Nogaro Blue S4
    South JerseY
    $100 wtf! Maybe it it made my car faster.....
    Sep 23 2006
    Houston TX
    yes, IDEAL gas law. as in it requires perfect conditions to be 100% accurate, which never happens in the real world. so end result, different gases do behave differently, negligible though they may be. Also, N2 should be slightly larger than O2, but not sure if that affects the rate at which it leaks out.
    Jul 04 2007
    MA
    Quote Originally Posted by Ill 3.0 View Post
    i've got an idea... how about you just fill up your tires a little more often and save 100 bucks?
    anyone who PAYS to get nitrogen because of the fact that nitrogen molecules are bigger than oxygen molecules is foolish.
    Sep 24 2007
    Chicago
    My friend, this is the exact same equations used to calc steam (steam is a gas) cycles in bio-fired and nuclear power plants. However, by all means, show me how you plan on disproving this.
    Don't let the semantics trip you up on the name: ideal gas LAW, you emphasized the wrong word. There are laws and there are theories, the operative word here is "law," nothing else matters. This is quite literally 100% accurate, 100% of the time.
    In conclusion, I repeat:
    Senior Member Three Rings va-terps4's Avatar
    Feb 11 2007
    NoVA
    Lugi20 is right. Anybody who can't get this straight needs to take a high school chemistry class. It's a LAW... Not a hypothesis... Not a theory... Not a maybe. It doesn't have any caveats. PV = nRT... PERIOD.
    Saying it doesn't work in the real world is like saying humans haven't been to the Moon. Believe what you want. Maybe you'd like to put a magnet on your fuel line? Can I interest you in a Turbonator too? With a little help, your S4 can get 100 mpg!
    2016 SQ5 Prestige - Glacier White/Black Milano/Carbon Atlas
    2013 Q7 S-Line ... 2008 S6 Sedan ... 2007 S4 Avant ... 2002 allroad
    Sep 23 2006
    Houston TX
    Quote Originally Posted by 1145climber View Post
    Um, that is what I do. I never said I use 100% nitrogen. Just looking for ideas why some people do.
    Feb 20 2005
    montreal
    You cannot use the perfect gas law. Nitrogen is not an inert gas nor a perfect gas.
    Jul 02 2004
    FL
    P = Pressure
    V = Volume
    R = gas constant
    T = Temperature
    If you read what I wrote you would understand that temp is a measure of kinetic energy the energy of motion(in this case molecular vibrations), and the stronger triple bound is less susceptible to changes in kinetic energy. The bottom line is the you would need more energy to cause the same temp change in Nitrogen gas than the same amount of Oxygen gas. And it is this CHANGE in temp that cause the tire pressure fluctuations.
    The Ideal Gas law does not function in all situations, it assumes IDEAL, not real conditions!
    BTW all the shit in your first paragraph has NOTHING to due with this discussion!
    Jul 02 2004
    FL
    Quote Originally Posted by va-terps4 View Post
    You sir are wrong. There are conditions, I take it chemistry was not your forte either.
    Sep 23 2006
    Houston TX
    I didn't mean to say it can't be used in real life situations, I wasn't aware it was. I was just saying that it won't be 100% accurate. I'm used to biological systems where "laws" are never describe the whole story. I also have no interest or knowledge to disprove PV=nRT. I also really don't care what people put in their tires, whether it be nitrogen or your ass gas as you mentioned. I was just thinking about reasons why it might be useful.
    Feb 11 2007
    NoVA
    For volumes and pressures as low as those found in a typical automotive tire, it simply does not matter that nitrogen isn't a perfect gas. The only parts of the nitrogen argument that make any sense are these:
    1. Nitrogen molecules are a little bigger than those of oxygen. They are theoretically less likely to migrate out of your tire between the rubber, steel, and kevlar structure.
    2. Pure nitrogen is usually delivered as a very dry gas. This means there is significantly less moisture in the gas to condense on cold days, and the insides of your tires will be less likely to rot as a result of the dry environment.
    HOWEVER... you need to keep a few things in mind:
    1. The air you're breathing right now is 78% nitrogen already. There is 21% oxygen, and another 1% of other gases mixed in. So how much impact are you really going to have with pure nitrogen? At most, 22%.
    2. Do the companies offering pure nitrogen purge the regular old air out of your tires (thus creating a vacuum) before they fill 'em up? Of course they don't. So you've already busted the whole pure nitrogen thing, and the humidity thing too.
    3. I've had tires that were purchased, mounted, balanced, and filled at Costco... with "pure" nitrogen. Guess what... they showed just as much pressure variance in temperature extremes as the factory set.
    4. You know what I did the first time it got cold and my pressure dropped? I pumped in a bunch of regular old air. Strangely, doing this didn't cause any extra sensitivity to temperature changes. Over the time I owned the tires, I needed to add air just as frequently as my old tires. The result... I had regular air in my tires shortly after they were installed.
    The bottom line on this is exactly this: If having nitrogen in your tires makes you feel better, go for it. But don't kill yourself to get nitrogen in your tires. And whatever you do, don't pay extra for it.
    Jul 02 2004
    FL
    I tend to agree with you, my statements were to address those who said it could not make a difference.
    As for the purging idea, I have never seen how they fill a nitrogen tire and had the same concerns, and thus I don't run it in mine either.
    Feb 11 2007
    NoVA
    Apparently debate wasn't yours.
    Seems to me that when tires get cold, they lose pressure... regardless of the gases inside them. Likewise, when they get hot, they gain pressure. Sounds pretty much like PV=nRT to me. Unless you have tires the size of the space shuttle's tanks or want to run cryogenic research with them, I really don't think any of your "conditions" are going to apply.
    But then... since you seem to be telling us you are a chemistry wiz, feel free to explain. I'd love to hear from a real expert on this one. Explain for us how PV=nRT isn't the right formula for this discussion.
    Sep 24 2007
    Chicago
    Not trying to pick fights or talk down to people. My apologies for rubbing anyone the wrong way.
    Jul 02 2004
    FL
    I wonder why you keep at this?
    Here is the problem, why you can not apply the I deal gas law to real gases.
    An ideal gas is defined as one in which all collisions between atoms or molecules are perfectly eleastic and in which there are no intermolecular attractive forces. In such a gas, all the internal energy is in the form of kinetic energy and any change in internal energy is accompanied by a change in temperature.
    This is not the case with real gases. Period.
    Can we be done with this now?
    Feb 11 2007
    NoVA
    It's all good... I enjoy a good discussion...
    Jul 02 2004
    FL
    Me too.
    Feb 11 2007
    NoVA
    I'm pushing it because I think the whole nitrogen in tires thing is bunk. I honestly suspect the nitrogen producers have contrived this as a method to sell more product.
    I understand there can be differences between gases... in very large volumes of gas, or super high pressures. But for the regular old tire scenario, is it really the case that swapping less than 22% of your air volume for nitrogen will make a noticable difference?
    Having run tires with and without nitrogen, I just don't see the difference in temperature variance. If there is a hard formula that can show the difference I'd love to see it. More importantly I'd love to see how big that difference really is.
    So... anybody know what volume of air a typical car tire holds? That would be a good place to start I think.
    Jul 02 2004
    FL
    Not that I'm advocating it's use but the reasons are more than just pressure fluctuations.
    Tires as well as most thing are porous the larger Nitrogen molecules may find it harder to escape (that is the thought) I'm not sure the role because of small difference in sizes. Oxygen is an enemy to many materials, (Oxidation) apparently the rubber in tires and valve stems also the metal in the stems and rims. Water vapor is also reduced as most tire shops do not have a proper working drier in their compressed air lines and as you compress air more water will come out of solution.
    So there are several reasons for it's use, they are all real issues but I'm unsure how much they affect US as our tires don't last that long to worry about oxidation, most shops change the valve with each tire change.
    For grandma who never even looks at her tires and run tires that are expected to last 60k nitrogen is a good choice, also for larger volume tires it would also be a plus, or if your car sits and is not driven often, for most of us (Car enthusiasts who drive their cars) it does not seem as relevant. This is just one man's opinion.
    Mar 17 2007
    new york
    it was the concept of the size changing for some people to understand......thats the whole gimic.....some places now when you buy tires they will it up with nitro....
    Registered Member Two Rings AVANT-GARDE's Avatar
    Feb 25 2008
    LONG BEACH CA
    Use Helium. Just be careful during those high speed bursts on the freeway. Youll end up flying right out into the stratosphere.
    2005 B6 S4 / Twin Turbo Pink Carseats... yea. fastest toddlers in town.
