Results 1 to 14 of 14
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    lets talk about staggered fitment...
    So how does the staggered fitment go on the quattro? i have a 2000 2.7t and i really want wider than 235 inthe back.. can i do staggered? i never understood the reasons for why not.. the car will be lowered with hr sports too
    Registered Member Three Rings m-avant's Avatar
    Aug 05 2007
    cars with wheels...
    Californication
    Re: lets talk about staggered fitment...
    From what I have read on AWorld and here, the concern is with rolling wheel diameter. If the rolling diameter between the front and rear wheels are drastically different - you can run into issues with the center diff. Make sure you purchase tires from the same manufacturer, as specs can vary between brands.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    old Avant (missed dearly) :2000 A4
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    so the next question is... if i go 235/40/18 in the front, how wide can i go in the back without rubbing on h&r sport springs?
    Aug 05 2007
    cars with wheels...
    Californication
    check this link out: http://www.1010tires.com/TireSizeCalculator.asp
    you also have to take into consideration the offset of your wheels - not just the width of he tires. this is what I'm running on my Avant : 255/30/20 on a 9.5 width rim @ ET 40mm. the offset just clears the outer fender and the inner suspension.
    ./mac
    baby hauler:2003 A6
    the daily: 2007 GTI
    track rig:99 M3
    Established Member Two Rings blueraj's Avatar
    Nov 15 2005
    02- A6 3.0 quattro
    i had a staggered set of wheels for two years with no problems. i had the following setup: 19X8.5 and 19X9.5 with 235/35/19 and 265/30/19. But i do recommend using 19x8 and 19x9 if you don't have the wide body a6, my set had that stretched tire look. the car was dropped with the Eibach pro-kit
    Mar 29 2007
    columbus, OH
    I have 4.2Q and presently shopping for tires, what would be the best setup for the same size wheels you have with a 35 offset?
    Nov 15 2005
    02- A6 3.0 quattro
    Quote Originally Posted by Audini View Post
    the same setup i had. unless you are not doing a staggered setup, where you would use or 19x8.5 or 19x9 all the way around
    Mar 29 2007
    columbus, OH
    Quote Originally Posted by blueraj View Post
    Wheels are 19x8.5 and 19x9.5 offset is 35. Wheels are staggered, will I need spacer to push the wheels out? Not knowlegeable about offsets, got a great deal on the wheels I could not pass up.
    Feb 16 2008
    08 Mini, 04 A6 2.7T
    Renton, WA
    I have a set of 19x8.5 and 19x10s with 35 offset all around on Eibach sport. If you like that look where the rear wheel is slightly out or just even with the fender (and a huge lip!) then go for it. I had 2 adults sitting in the back seat with no rubbing issue. I'll try to post some pics today to give you an idea.
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    hey if i get H&R sport with the 19x8.5 and the 19x10 with 35 offset... will i rub? i know that with the eibach i wont rub, but what about the HR sports becasue i know that those have a more aggressive drop...
    Feb 16 2008
    08 Mini, 04 A6 2.7T
    Renton, WA
    Here are the pics that I promised. The cars a little dirty....
    Nov 14 2006
    600hp glorified Beetle, Tacoma, motorcycles
    Renton, WA
    Click the second link in my sig for everything and more than you ever wanted to know about staggering wheels with Quattro.
    -Darrick
    No more Audis, but I can't seem to leave this place.
    Mar 29 2007
    columbus, OH
    Quote Originally Posted by Capt. Obvious View Post
    Car looks great. I won't have to change the camber on mine since I have the4.2. Wheels should fit fine.
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    I love your car, can't wait to see the painted lowers.
    BTW, doesn't your car understeer madly with this staggered setup?
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
