Results 1 to 19 of 19
    Veteran Member Four Rings Rotond0000's Avatar
    Apr 30 2007
    Rhode Island
    lowering on coilovers...
    im getting my coils installed next week. ive decided on how low i want to go...but i dont know how to put it into a level. i dont know how the ajustment levels work. I have STaSIS SS coils and i was just wondering if anyone would be so nice to post pictures of there cars on STaSIS SS and tell me what ajustments/levels they are on....
    thanks in advance.
    - 2011 A4 2.0T Quattro - 6 Speed Manual - Black/Black - ST Coilovers - 20% Tint - Smoked Tails - Smoked Corners - 6000K Headlights And Fogs - Full LED Interior Lighting Conversion - Custom LED Headlight Strips - RS4 Grill W/ Blacked Out Euro Plate -
    Apr 30 2007
    Rhode Island
    Re: lowering on coilovers...
    bump cmon people little help here?
    Apr 30 2007
    Rhode Island
    seriously i hate to sound like a noob with the thread to start with but u mean to tell me that nobody here has coilovers?
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    if you are getting them brand new, Stasis presets them to what they think is optimal for our cars (which is setting it at a level chasis too). From there you can fine tune if you want.
    You meaure from ground to bottom of fender to determine height. For reference sake, my front is a touch less than 25 1/2, rear is 25 even. Front end "should" be a little higher if you don't want it to be nose heavy. Plus the fender themselves are not level to each other (hope that makes sense, can't describe it very well).
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Apr 30 2007
    Rhode Island
    Thank you!!! thats all i wanted to know....
    Sep 26 2004
    STL
    Quote Originally Posted by A4ItaliaGT View Post
    np
    05 S4 6MT silver
    Present:
    Veteran Member Three Rings tribe's Avatar
    Feb 15 2008
    lotsa tools
    Vienna, VA
    I installed my Stasis a couple of days ago. My rear is 25 1/2 and front is 1/4" higher (from the lip of the fender to ground).
    To achieve this height I left 5 visible threads in the inside of the rear collars (difficult to measure with any device)
    The fronts are easy; I left 75mm of visible threads under the biggest spring perch ( I dropped the smaller adjuster ring to the bottom of the shock to measure)
    hope this helps as a guideline.
    '12 Phantom Black S4 P+ S-Tronic- Navi - 3M Clear Bra - KW Springs - REVO Stage I - AWE S-Flo Intake - Hotchkis sways (still in the box)
    Apr 30 2007
    Rhode Island
    can i see sum pics of ur stance?
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Didn't take pics yet but this is a snap today looking for some country roads.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    looks good. props
    Veteran Member Four Rings INTEGRATION's Avatar
    2006 A4 2.0T Quattro 6MT
    AWD_4TW
    Quote Originally Posted by autoverrückt View Post
    I know this crosses into "driver preference" territory but having a higher front end also results in more understeer :(
    2006 Audi A4 2.0T Quattro 6MT S-line
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    So would it be better to be the same height front and back? Which is what I want to do. I'm getting FK coilovers in a week or so and I'm installing 19s VMR reps. I
    m thinking about a 26" ground to fender height all around.
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Quote Originally Posted by Kid Red View Post
    The car is designed to have a bigger clearance in the front fender but that doesn't mean that the car is higher in the front. With my setup - 1/4" higher in the front fender lip-to-ground - the 'ground clearance' of the car is still 10mm higher in the rear.
    Feb 05 2008
    Orlando, FL
    I see. I just don't like the look where the rear is sitting on the tire, but the front has a gap. I want them to be as even as possible while not affecting anything negatively that I don't know about. Does 26" high sound like a good number to go from? Or should I just go with the default FK setting? I like the stock RS4 look, which I read was like 1.2" below my base A4 height (which puts it around 26")
    Feb 15 2008
    lotsa tools
    Vienna, VA
    26 is a good number. I don't know about FKs but I fear that the rear of the Stasis would be sitting on only a couple of threads at 26... I don't know if it's doable
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    I'd highly recommend you get your car corner balanced after you put your coilovers on. IMO, the whole point of coilovers first and foremost is improved handling, and looks second. If you really want to get your handling dialed it, you really should get your car corner-balanced -- it makes a WORLD of difference.
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Quote Originally Posted by lnferno View Post
    +1. And as far as height is concerned, I wouldn't go too low for a daily driver. I'm going with 25.25R and 25.5F.
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Feb 15 2008
    lotsa tools
    Vienna, VA
    Does corner balancing imply adjusting height of a determined wheel/s to make them distribute weight equally? Sorry for the noob question but I've never heard of this before.
    how much does it +/- cost?
    AWD_4TW
    Quote Originally Posted by tribe View Post
    Read the article in the link below for a good explanation of what corner-balancing is:
    http://www.elephantracing.com/techto...nerbalance.htm
    The cost amount would depend on the shop that is doing it for you. Keep in mind that legitimate shops would generally cost more than others. Oh and something else to consider. Be sure to remove "extra weight" in your car if you want an accurate setting and make sure whoever is performing the corner balance on your car makes you sit in the car while he/she is doing it.
    Edit: height settings are somewhat independent from corner balancing.
