Results 1 to 21 of 21
    Jan 11 2007
    Salt Lake City, Utah
    How does the GT turbos need to be modified to fit?
    Title says it all, what needs to be done to normal GT's to have them work in our car?
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    Re: How does the GT turbos need to be modified to fit?
    How DO the gt turbos need to be modified to fit?
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    they bolt right in, do a search for user generationjdm
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Yes they bolt right in if you have changed manifolds, intake and downpipes, oil and water lines.
    So you don't modify the turbos, you modify the parts connecting to it.
    Jan 11 2007
    Quote Originally Posted by infinkc View Post
    He's why I ask.
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Whe have to modify the wastegates .
    Get rid of the flapper and have the wastegates holes welded up.
    That is the only mod you need to make em fit in a kit...
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Actually you need to modify the gates like Guru said also you need to add a reference line for boost in the comp housing and lastly you need to modify the compressor nozzle to except an aluminum 90... Theres know more or less work then doing a normal k04 install.
    Dec 07 2004
    Finland
    Ok I forgot those little things.
    Why don't you use the internal wastegate? Don't you think that it wont flow enough?
    Mar 13 2007
    Montreal
    I dont use these lines no more.
    Mar 13 2007
    Montreal
    You get more accurate boost control with externat, and they fit better
    Mar 14 2007
    michigan
    Quote Originally Posted by GURUMAN View Post
    what r u teeing into if you dont use any reference from the turbo?
    Mar 14 2007
    michigan
    Correct, everyone has had internal gate troubles at 1 point or another with other kits... you cant beat the external gates
    Mar 13 2007
    Montreal
    Troubles are comming as soon as you ask over 15psi with internal gates, it's hard to get a good boost control.
    I know from a fact because I had them before on my S4.
    Mar 14 2007
    michigan
    You should always use these lines... Using the intake manifold is great for plumbing your boost gauge but for controlling boost its much better and safer to read it straight from the compressor cover, this is very important to do and thats why I plumb them there.. You want to always control the boost at the compressor housing and read it at the intake manifold.. Food for thought.
    Dec 07 2004
    Finland
    Have you got any photos? How big those turbos are? HP?
    Veteran Member Four Rings flips4's Avatar
    Oct 27 2006
    01.5&06 S4,04 MCS,08RangeRover, Ducati 848, YZ250F, and lots of TOOLS!
    Ocean Springs, MS
    If it aint broke... Dont fix it!
    Mar 13 2007
    Montreal
    This turbo is way to big for your application unless you go single turbo.
    A hx35 is comparable to a gt35R [O_O]
    What are you building, a Rocket ?
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Quote Originally Posted by TipsyS4 View Post
    I'm in the process of fitting two Holset HX35's. So far they appear to be a direct bolt on, just need to re-drill the factory manifolds. All of the oil and coolant lines are a perfect match. The best part about these turbos is I got them for $100 a piece from my nephew's salvage yard.
    Can you post up some more info on this? Pictures? Don't the Holsets have like the classic T3 manifold? How do you make them work with our manifolds? And you say that the oil and coolant lines all bolt up fine? How far are you on the project? What are you planning to do for fueling and software? I am quite interested in this to see how it turns out.
    Mar 14 2007
    michigan
    If they have a t3 comp housing they can't and will not fit 100000000000000000%%%%%%%% the t3 comp housings don't even fit with my manis or most of the others
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Quote Originally Posted by generationjdm View Post
    That's kind of what I thought too? I mean the T3 manis are lot bigger, and square vs round like the K03s right?
    Mar 14 2007
    michigan
    The best person besides myself and a few others would be Guru to answer this.. He had one of the only gt2554 turbos on a stock mani and ask him how that worked out.. The cover on the gt2554 is about 30+% smaller then the T3, he was looking at the drivers side not the passenger side and once he puts the starter on then he will understand it could never happen...
