So today a friend wanted to check out my engine, so I pop the hood and to my horror, I immediately noticed oil all around both the left and right sides of the valve cover in my 2007 B7 2.0T's engine. Oil was also pooled up in many of the areas where the bolts hold down the valve cover. To top it off, it seems it's also coming from behind the timing belt cover area.
As you can imagine, I'm thoroughly pissed and have to take the car into Audi this morning (Thursday) @ 8am for them to fix it. I'm sure they'll need the car for the full day as well.... so they better give me a decent rental off their own lot. None of this "enterprise rent-a-POS".
The oil level isn't actually that low. Probably 1/2 way between min and max.
What do you guys think about my diagnosis of this problem? I also noticed that many of the bolts which secure the valve cover to the head also seemed less tight than they definitely should be.
Here are a few shots i took after wiping down some of the oil....
